Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman 1/2 Recently, my garage door came off track. I fixed that problem but now my remotes and outside panel won't work. I tried to reset them with the learn button but the door will only move a couple inches and stop and the light flashes several times. I don't have a manual and can't seem to find one for this model (139.53681B) Any help would sure be appreciated.
  • 504 Answers
Try free pdf download
The diagnostics in the manual should help.
Posted on May 30, 2010
  • 2992 Answers
SOURCE: craftsman outside keypad
On the back panel of the opener itself is a small pushbutton. Press the button and the indicator near it will light. While the indicator is lit, enter the new 4-digit code on your keypad and it will be set. (You are actually programming the receiver with the new code this way. The wireless keypad doesn't store a code.) The programming light goes off on its own.
Posted on Feb 13, 2009
  • 3197 Answers
SOURCE: I have a Craftsman 1/2 HP model #13953975SRT1.
It is normal for it to blink randomly. If you watch it while you press your remote you will see what it looks like when it is receiving a properly coded signal.
Posted on Jun 01, 2009
  • 3197 Answers
SOURCE: owners manual for Craftsman garage door opener
This is available from Sears. The part number is 114A1930 and it sells for $4.99.
Posted on Oct 05, 2009
  • 3197 Answers
SOURCE: garage door opener won't close. travels 6-8 in.,
If you cannot get the light on the sensor to come on by tweaking it,making sure it is pointed at the other sensor and your wiring is not broken or shorted then your sensors need to be replaced.
Posted on Jan 08, 2010
  • 16 Answers
SOURCE: how to program keypad outside of garage
Don0930's answer is for the wireless keypad most folks have. My 1993 opener has a digit type keypad that is wired to the opener motor. See if yours is. It doesn't run on batteries but has a plug in transformer box to work. If you have one like mine, then you have an indoor button on a plastic box. You can lift the cover off that box, where it says "Sears digital solid state control" (pries off at the seam) and inside you will find a switch, with two positions, one is "program" and one is "operate". Flip it to program, enter your 4 digits, flip it to operate. Should do it. There is a place for a 9v battery under that same cover, it holds your code in a power failure. I think if you have a dead battery, and the unit loses power, it defaults to 1234.
Posted on Feb 13, 2010
I recently bought a house which has a craftsman 1/2 HP garage door opener. The garage door opener works fine using the wall mounted pad and also the numeric key pad, but not with the remote that came with...
If you didn't, try programming the remote this way.
Press and hold the button on the remote and then press and immediately release the smart/learn button on the motor unit. If this doesn't work you need to make sure you have the correct remote for the model opener you have. Your model number doesn't bring any results from Sears
Nov 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
While trying to reset the outside panel the remotes wont work and the door wont go down or up with the wall unit or remote. I have tried reset but its doesent work. What else can I do?
Make sure the opener is still plugged into the outlet and that the breaker hasn't popped. If you held the smart/learn button in for 6 seconds it would erase the memory and the remotes would not work but the wall button should. Sounds like no power to the opener.
Aug 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hi I have a sears craftsman garage door opener. I initially replaced the outside opener with a CLK1 - it worked fine after a chat to clickerproducts. Now I have replaced both the car remotes and no matter...
It sounds like you bought the wrong car remotes. The model number for your opener is on the end closest to the garage door. Using it you can get the correct remotes.
Jan 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2hp garage opener Homelink must be under unit to work
Have you tired reprogramming the remotes to the opener?
The opener receiver board may have failed, which happens. You can order a new one from Sears or other places on the Internet, and they are fairly easy to replace.
Once replaced, you will need to program the receiver to you remotes again.
Dec 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
When I push the button it only runs for 1 sec and stops...even with the door manually removed from the track system..I have a craftsman 139.53603 opener.
my craftsman garage door open about one ft and stop when i try to push the wall button or the remote pad it completely stop working
Oct 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 3/4 screw garage opener all remote stopped working
The radio receiver which is part of the logic board is bad. Check your warranty quick and call Sears.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman remote -- new battery installed..
close the garage door, press the lock button so that's it's blinking, press the red reset button on the craftsman, then press the remote.... that should work
Feb 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
83 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Are you a Sears Building Material Expert? Answer questions, earn points and help others
