Need to reset or set up my router - Computers & Internet
  • Byron Wells May 11, 2010
    need more info on problem and router.
    Problem Solver:
  • 19 Answers
Go to: start/all programs/Accesories/Command Prompt
In Command window type: ipconfig
Get default gateway address: XXX.XX.X.X (for example:172.16.0.1)
Go to browser type: http://aboveaddress (i.e., http://172.16.0.1)
You will see router setup window which you can reset
Posted on Apr 29, 2008
    Genius:
  • 3,587 Answers
Well...model numbers on computer and router would accelerate this issue.
My computer will not connect to my wndr3800 router but my computer will connect to my neighbors router
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
To perform a factory reset:
  1. On the back of your router, locate the Restore Factory Settings or Reset button.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
    After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
    Note: The Power light on newer router models lights solid white.
    The factory default settings are restored.
  4. or you can visit youtube for the video https://www.youtube.com/watch?v=nUOcjDy02ts.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
Feb 05, 2017 | Computers & Internet
Reset password
The Motorola WR850G is a wireless router that attaches to a cable or DSL modem. The WR850G has two reset options.
Users can reset the router and retain the settings or reset it back to factory specifications to clear all settings.
Resetting the router can help with network issues such as dropped connections.
It can also resolve situations where the user has made changes to the router's settings and can no longer connect to the router.
Look at the back of the Motorola WR850G router and locate the reset button. It is a red button located to the left of the Ethernet ports.
Press the reset button on the Motorola WR850G router, and release it immediately to reset the router without changing the settings.
Press the button on the Motorola WR850G router and hold it for longer than five seconds to reset the router to factory specifications.
This setting resets the router's IP address and subnet mask along with the user ID and password you use to log in to the router.
http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_userguide.pdf
May 15, 2013 | Arris WR850G Router (DHWR850G)
Router name was reset without my asking. i need to set it back.
how was the name reset and by who??????
if you mean you have to reset your router to the factory default settings
(note all settings will be lost you will need to reconfigure the router)
you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, depending on your router) to reconfigure your router settings or if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Jun 26, 2011 | Computers & Internet
My wireless router number is WRT120N but I dont remember my pin number how can I can a new one
You need to reset your router to factory setting.
The reset process will restore your router's factory default settings. All of the customized settings of the router will then be erased and the router's IP address will be reverted back to 192.168.1.1 if you have changed it.
To perform a hardware reset on your Linksys router, follow these steps:
Resetting the Router Using the Reset Button
IMPORTANT: Before proceeding with the reset, take note of your router's current settings. You might need to check with your Internet Service Provider to get settings.
Press and hold the Reset button at the back of the router for ten seconds. It will reset your router to factory settings.
Apr 11, 2011 | Linksys Wireless-G WRT54G Router
I need to rest my router
YOU CAN RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory setting from the reset button on the back side of the router. Use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
HOPE IT HELPS...Let me know if you need any further assistance
CreativeTECH
Nov 16, 2010 | NetGear Computers & Internet
Need to reset Belkin N wireless router
well, to reset the router press and hold the reset button on the back of the box for 10-15 seconds.
Mar 07, 2010 | Belkin N1 Vision Wireless Router
I have the password setup, however do-not remember it, need to reset pls
Right near the arial there is a reset button sitting behind the grill. Just look carefully and you'll find one of the grill hole is covered with a half white plastic. This is your reset button. Press it for ten seconds and router will start loading default setting.
Sep 07, 2009 | NetGear WGR614 Wireless Router
Router password trouble
you may try resetting the router settings by pressing the reset button of the router at the back of the router, there is a hole at the back of the router, you need to have a paper clip or any ball point pen to press the reset button of the router. The catch in here is all the settings of the router will set back to factory default so if you will be resetting the router allo the settings you have configured and set on the router will be set back to the default settings so you might alos loose your Internet connection.
Default settings on the router's log in - nothing for username and password is admin. Username as in blank and don't put anything into it.
Jul 07, 2009 | Computers & Internet
Forgot my belkin router password is there a way to reset it?
here you go, from Belkin's website
Reset the router to factory default Resolution With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings. SummaryThis article describes how to reset the router to factory default More InfoThis article assumes you cannot access the routers web interface.
Jan 26, 2009 | Computers & Internet
Lost password into router need reset
Use the reset button near where the AC adapter plugs in. Hold it in for at least ten seconds. This should set it back to factory, allowing you to set another password.
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
