Question about MTX Thunder 1501D Car Audio Amplifier
MTX 1501 D
I recently just added a optima yellow top to my system and today when i cranked it up really loud the amp started emitting smoke from the power and ground terminals. It was a very light smoke but noticeable. What would cause the amp to smoke? Also when i touched the amp it was ice cold so I doubt it was an overheating issue.
  • Joshreal69er Apr 30, 2008
    I took the cover off the amp today and it has some fried circuits output resistors i think is what they are called. four of them are burnt. Does anybody know where i can get the parts to fix this amp?
  • 631 Answers
If the terminals were smoking, it's probably due to loose screws in the terminal block or wire that's too small.
Did the amp work properly after the terminal blocks smoked?
Posted on Apr 29, 2008
  • Perry Babin Apr 30, 2008
    You'll need to provide the circuit board designations (Qxyz, Rxyz, FETxyz...) for the defective components.
F450 2011 DRW diesel - check brake system light comes on 3 minutes after crank. Once light comes on no power to dash lights, power windows, sunroof, seats, or mirrors.
This could be a safety problem have ford run the VIN # to see if your truck is included in this recall. During this mode of nonoperational items the power feed is grounded but not pulling enough amps to blow its fuse but can be burning the wiring until other wires start the same thing then truck is up in smoke.
May 06, 2014 | 2011 Ford F-450 Super Duty
I just recently bought a brand new MTX magnum amp and dual 10" enclosed subs deal off of amazon. They arrived today, and with the help of a friend who is good with car audio systems, we set the whole
the best thing to do is get in touch with amazon,and see what they can do about it,if you try to fix the problem yourself it will invalidate the garantee!
Dec 05, 2012 | MTX Car Audio & Video
I have a Hyundai Trajet 2002 Gasoline. I have a problem with keeping the engine alive.
The engine is running very rich that is why the exhaust is emitting black smoke. The engine needs a tune up so the air fuel mixture is correct.
Dec 02, 2012 | Hyundai Cars & Trucks
My s10 emits white smoke when cranked...how do I stop it from smoking when cranked?
White smoke is usually coolant being burned in the cylinders.
If that is the case, I would expect to find a leaking head gasket or other serious engine problem.
Are you adding coolant or oil during the month ?
Jul 15, 2012 | 1992 Chevrolet S-10
Car stereo
check your amp to see if its on high or low setting in order for it to bump it needs to be on low thats all the bass settings and you shouldnt hear the words come out of your subs
Nov 01, 2009 | Car Audio & Video
White smoke from Exhaust
hardly likely the exhaust job would cause that, but yes it sounds like you got a blown head gasket. badl lock stricks hmm! also preasure test cylinder head for leaks
Jul 22, 2009 | 2005 Renault R5
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
MTX 1501 SCHEMATIC DIAGRAM
MTX never released any of their schematics.
What sort of problem are you having with it?
Sep 29, 2008 | MTX Thunder 1501D Car Audio Amplifier
MTX Thunder 1501D Car Audio Amplifier Logo
194 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
