Question about Autodesk Autocad 2004 for PC
Autocad lt2005 loads program intalled improperly on opening
  • 73 Answers
Uninstall and reinstall Autocad
Posted on Oct 31, 2008
Error opening AutoCad file
This error can have a variety of causes....corrupt drawing, a program corruption, or a problem with your system configuration.
There are several ways to troubleshoot the problem: try opening another drawing ,uninstall any antivirus or desktop locking programs or update your graphics driver. If it useless so your file is damaged. In this case you can try to recover it with the help of https://www.fixtoolbox.com/autocadfix.html
Feb 21, 2017 | The Computers & Internet
Code activation
Before you can use the AutoCAD 2007 software on your computer, you must import your license key into the program.
You received this license key after purchasing your copy of the software.
This key confirms to the software that it wasn't pirated, and allows you to use all the features available to you in the AutoCAD 2007 software for whatever length of time you choose
Open AutoCAD 2007 (if you haven't already) using the icon in your "Start" menu.
Click "Edit" at the top of the "AutoCAD 2007" program window.
Click "Options."
Click "Registration."
From this window, click "Activate Now."
Type your license key into the window on the screen and click "Activate."
This will import your license into the AutoCAD 2007 software.
utoCAD 2007 Tutorial - User's Guide
http://www.tutorialspdf.com/autocad-2007-tutorial/
Jun 03, 2013 | Autodesk AutoCAD 2007
Please tell me the procedure to intall Autocad 2007
Procedure to intall Autocad 2007
http://www.rawledu.com/draft/pdfs/Autodesk_Design_Academy_2007_Install_Guide%5B1%5D.pdf
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Computers & Internet
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
HOW WE INSTALL AutoCAD 2011 ON WINDOW 7
how to install autocad 2011 step by step
Sep 09, 2010 | Autodesk AutoCAD 2010
When I open a file that is associated with autocad, autocad opens the file and the program at the same time. But if I already have autocad open and click on another file, instead of autocad opening that...
Turn off your single document interface. Type OP and hit enter. Then select the system tab and check off the SDI (it should be towards the upper right of the dialogue box.
Nov 24, 2009 | Autodesk AutoCAD 2006
Opening dwgs. in autocad 2004
Try rebooting your computer, then relaunch AutoCAD. If your .dwg file will not open then open the backup file. Sometimes the .dwg file goes crazy and the backup file will save your life, most of the time. Also make sure that your machine has enough memory to run AutoCAD. Memory is either your best friend or your worst enemy when working with AutoCAD. I hope this helps.
Apr 08, 2009 | Autodesk AutoCAD 2004 for PC
Windows vista will not open autocad 2004 after being loaded
All you need do is got to autocad website and download the autocad lockeds1. its a patch it works for pirated autocad as well.
Mar 02, 2009 | Autodesk AutoCAD 2004 for PC
AutoCad R14 to Vista - bab-Mem-Pointer error message
You are still using AutoCAD R14? If you are that might be the problem. If you are running Vista, then AutoCAD R14 might be too old of a version to run. You will probably need to upgrade to a newer version of AutoCAD. I know this isn't a solution, but I am just trying to look at it from a different point of view. You can also go to autodesk.com and join their discussion groups. It is free and you can post questions. You usually get a fast response with an answer that really helps. I will do a little more research and add more when I get a chance. Good luck and I hope that I helped.
Feb 22, 2009 | Autodesk AutoCAD LT 2008 - Upgrade for 5...
Is it ok ?
I don't understand what you are trying to say. Could you please explain deeply what you are trying to say and what you want to do with autocad.
May 30, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
