Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
Power to mouse/keyboard when off
After I shut my pc down the laser for the mouse is still on as is the numlock on the keyboard. Then only time they shut off is when I flip the main power switch on the back of the tower. Is there a away to keep these 2 items from remaining on when the pc is off? BOth are plugged into the PS/2 slots.
  • 472 Answers
You will have jumpers near the PS2 and USB ports on the motherboard. They control if there is +5v standby running to the keyboard, mouse and USB ports to use as an alternate wake up for the system. The USB can also be used to charge things while the computer is technically off..so it's a handy feature when needed.
Posted on Apr 29, 2008
  • 56 Answers
Check your BIOS settings, sounds like it may be an issue there. If nothing there, could be a problem with the MB.
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: http://www.aten.com/download/download.php#productGuide (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Tip
Mouse pointer with keyboard keys
<span><b>You can control your mouse pointer with keyboard keys in all windows versions. When your mouse stops working, you can enable this keyboard feature to complete your important work. This keyboard mouse can performs all tasks same like a normal mouse.</b><br /><b>Follow the given steps to activate the keyboard mouse:</b><br /><b><br />To edit this feature, first you should log onto your computer with administrative rights.<br />To activate this feature, press Alt+Shift+NumLock keys at once and you will receive a small MouseKey box.<br />To keep MouseKeys on, click on Ok button or click on cancel button to cancel MouseKeys box.<br />Click on Settings button, if you want to adjust the mouse cursor detail settings.<br />Here a new dialog box will appear with the title Settings for MouseKeys", now you can manage all mouse settings for example mouse cursor speed, acceleration and some other features.<br />Now using Numeric keypad, you can move your mouse pointer. The controls are:<br />*<br />1,2,3,4,6,7,8 and 9 keys are used to move the mouse cursor into different directions.<br />*<br />Key 5 is used as mouse click button.<br />*<br />Insert key used to hold down mouse button.<br />*<br />+ Sign used to double click on any object.<br />*<br />Delete button used to release the mouse.<br />*<br />Click on NumLock button to disable this keyboard mouse feature</b></span>
on Apr 04, 2011 | Computers & Internet
Logitech Laser Mouse not working properly
Nothing to worry Just your LED has given way due to long usage. It seems you never switch off your UPS or power supply properly because you can monitor for yourself even after shutting down your red laser on the mouse will keep on glowing until you switch off the power supply to CPU. You can use your mouse without that LED also.
Sep 07, 2009 | Logitech Cordless Desktop MX3200 Laser...
Acer Notebook Keyboard is locked
Just hold down Fn then press F7 or F8 keys to unlock keyboard.
Good luck.
Aug 14, 2009 | Acer Aspire 4315 Notebook
Help me turn off the Mouse!!!!
Most laser mice don't switch off - even the battery powered types have no off switch.
Jul 14, 2009 | Logitech EX100 967499-0403 Keyboard
Wireless mouse and keyboard issues
If you have both sets of keyboard and mouse plugged in, turn off the computer and remove the old mouse and plug in the new mouse. Reboot and if necessary use the keyboard to login. Once windows is loaded let it detect the new mouse and then shut down again. Take out the old keyboard and reboot. You should now be able to use both new pieces without problems.
Jun 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Microsoft Wireless Keyboards 6000v3 loss of BIO's on computer
You need to completely shut down your system. Power off. Unplug the power cord for 3 or 4 minutes. Plug the cord back in and try again but I would do so the first time without the new mouse and keyboard. Checksum errors are ram memory errors most of the time. the ACHI Bios error is bad new also. I think one or more of the new devices is bad. They could have a dead short in them that is causing severe problems with your PC that if it continues could cause some real damage.
Jun 01, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Wireless mouse and keyboard not working properly.
GO TO POWER SETTINGS IN THE CONTROL PANEL AND CHANGE YOUR SETTINGS TO ALWAYS ON. BUT LEAVE HIBERNATION ON IF YOU WANT IT TO SAVE POWER. YOU MAY HAVE TO TURN THIS OFF ALSO.
May 27, 2009 | Microsoft Wireless Laser Mouse 5000
I cant use my number pad on the right side of my keyboard.
Have you tried pressing the NumLock-key?
It is located right above the key "7" on the numpad/calculator pad.
Dec 17, 2008 | Logitech Cordless Desktop MX3200 Laser...
Mouse and keyboard not recognized on second computer
Solution for the mouse. I have 8 KVM's. Most of my computers work with the KVMs. On 1 inland KVM the logitect and Microsoft optical mice do not work on one computer (but work with the other computers). They both are USB. I hook them up with a USB to PS2 adapter. If I use a ps2 ball mouse connected to the KVM the mouse works. All the Mice work if I directly connect them. Since I do not want a ball mouse I got a Frisby optical PS2 mouse. It works with all the computers on the KVM's.
I do not have a solution for the Keyboard yet. 1 computer (ASUS MB) on my trendnet or belkin 4 postion KVM does not recognize the keyboard.
Aug 25, 2008 | D-Link DKVM 2K (DKVM-2K) 2-port KVM Switch
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
93 people viewed this question
Top Foxconn Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
