Question about Samsung UpStage SPH-m620 Cellular Phone
Motorola H500 not able to connect to Vista
I was able to get Vista to pair with the headset and I see it in the devices. When I click on the Audio tab and the select the H500 and try to connect it will say connecting for a while and the disconnect. It is acting like it does not have the permission to connect. I did add the 0000 when I paired it.
I GOT MY BLUETOOTH TO PAIR BUT I STILL CAN HEAR ANY SOUND
  • Peter Hung Jul 11, 2008
    I have the same problem.
  • Dave St Nov 26, 2008
    I installed a bluetooth headset, Motorola H500, and the installation "appears" to be OK, but I get no sound in or out except a low hiss that makes me think it really is connected. I saw a message indicating a driver might not have installed properly. I called Motorola and the headset started working whlie I was talking to them - they didn't suggest a fix, it just started working. It worked flawlessly for a week. I uplugged the Bluetooth dongle and replugged it, now it doesn't work again. This time it has not "fixed" itself. All settings remain the same.
  • 3 Answers
I had the same problem w my Compaq Presario V3000 HP BT module. I installed the HP Bluetooth drivers from hp.com and that fixed it. So instead of using Vista's built in stack, try one that your manufacturer may have issued.
Pim from the Computer People
Helping Kiwis go places
Ph. +64210398346
Posted on Aug 18, 2008
Pairing motorola h500
Pairing mode is what is shown in the picture. The headset has a steady blue light and is ready to be paired with another device.
Mark
Motorola Support
Jun 08, 2014 | Motorola Mobility H500 Wireless Headset
I need help pairing my motorola h500 to motorola i580 phone
  1. Make sure your phone's bluetooth is on.
  2. Go to MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > SETUP.
  3. Scroll to power then press change.
  4. Scroll to ON the press select to turn on the bluetooth feature. Bluetooth feature remains ON until it is turned off.
  5. With the headset power off, press and hold the CALL button for 6-10 seconds until the blue light indicator turns on and remains steadily lit. If it does not stay lit, turn off the headset. To turn it off, press and hold CALL button until blue light stops.
  6. While holding the CALL button on the headset, on your phone select MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > HANDS-FREE > LOOK FOR DEVICES. The phone lists all bluetooth devices it finds.
  7. Select Motorola H500.
  8. Press OK or YES to pair the headset with your phone.
  9. Enter the passkey 0000.
  10. Press OK.
Oct 08, 2009 | Motorola Mobility H500 Headset
Pairing my headset
go to were you find the name of the headset in your phone and click options, is there a connect option? if so you must click ok on it and this will connect......... from-KERFEW-LOS ANGELES
Mar 09, 2009 | Motorola Mobility H500 Wireless Headset
HOW TO PAIR MY MOTOROLA H500 TO SAMSUNG CELL PHONE?
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Dec 26, 2008 | Motorola Mobility Bluetooth Hands Free...
H500 Headset Problem
This is the same headset I have.
I believe you have to hold the power button in until the light starts to blink, then tell your phone to look for the device. Don't forget to remove the device in your blackberry if you are still using it.
Nov 04, 2008 | Motorola Mobility H500 Headset
Motorola H500 Headset Problem
TRhe pair code for my motorola headset is 0000 (that's zero zero zero zero)
Oct 16, 2008 | Motorola Mobility H500 Headset
How do you connect a Motorola H500 Headset to a motorola razor v3m
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Enjoy!
Jan 14, 2008 | Motorola Mobility H500 Headset
Problems With Pairing H500 and Motorola V190
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 24, 2007 | Motorola Mobility H500 Wireless Headset
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
Samsung UpStage SPH-m620 Cellular Phone Logo
758 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
