Question about Kitchen Ranges
I have a smooth top electric stove. I accidentally dropped something on it from the cupboard above the stove and put a large chip in it. That chip became a long crack that now goes from the bottom to the top of the stove. Is it still okay to cook on it with a crack down the middle?
    Genius:
  • 1,073 Answers
NO THE CRACK COULD HAVE RAN THROUGH THE TOP AND ELCTRICUT YOU
Posted on Apr 29, 2008
Can the cooktop surface of my Kenmore gas range model 790.72903011 be removed
Most stove tops are removable for that very purpose.... after you remove the burners and the grills above the burners.... look for an edge and inch or inch and a half below the top... get something strong like a large screwdriver and place cloth over the tip to prevent scratching the stove top. there are VERY STRONG CLIPS holding the stove top to the stove, pry upward until the clips release. then slowly remove the spark igniter (TAKE A PICTURE WITH YOUR CELL TO REMEMBER HOW PUT BACK TOGETHER)
Jul 30, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Tip
Dropped it it water?
This happens quite often, someone accidentally drops their camera, mobile phone or whatever electrical device in water.
Always worth trying, but can't guarantee the outcome, some times it works ok, sometimes it doesn't but, it doesn't make anything worse either.
First and most important thing to do is take the batteries out. Straight away as soon as physically possible.
ie;- out of the water , out come the batteries, out come any memory cards.
With luck you've saved it, now open any cover or slots that you can and pour out any water that will come.
Dry it off and take it home then put it in a warm dry place for a few days some where like an airing cupboard or above (not on) a radiator.
Give it time to dry out thoroughly, if there's any mist on the screens, its not ready, then put the batteries back in and give it a go.....................good luck
on Apr 14, 2011 | Cameras
While oven on range top front is very hot
I do not know the unit but check if the oven vent is near the front. It is also possible the door seal on the top of the door is failing.
Apr 13, 2014 | Kenmore Electric Smooth Top Stove
How do I remove over-the-stove Amana microwave?
open the cabinet above the microwave there should be 2-3 screws going into the top of the microwave remove those and the microwave should drop down. but put something underneath they can drop fast so be careful
Jul 24, 2012 | Amana Microwave Ovens
My stoves oven is burning my kitchen cupboards
If you could provide some more information, then I may be able to help. What part of the oven is causing the problem, i.e. top or bottom door. If the doors don't shut properly then this may cause the hot air to escape. If it is one of the doors, is it sitting square in the frame?
Feb 20, 2010 | Stoves 720EF Electric Double Oven
How do I lift the top on a smooth cooktop electric stove. I believe there is something under my cooktop that should not be there.
General put screw driver between stove top and over and lift.....it just snaps on there.........abb
Oct 26, 2009 | Kitchen Ranges
Electric stovetop gets VERY hot
LIFT TOP FROM FRONT ABOVE OVEN DOOR. TURN OFF POWER BEFORE SEVICING.
Oct 20, 2009 | Maytag MER5775Q Electric Kitchen Range
Repair large chips to white enamel on stove top.
Get some glass enamel powder the same colour of course...I got it off ebay.or go here.www.find-a-fix.com/
Aug 29, 2009 | Cooktops
Large element burns high
The problem is in the switch not the element.
Mar 24, 2009 | KitchenAid KERC507 Electric Kitchen Range
I have a smooth top range that has enamal edges. On two different occassions I have dropped a LIGHT ceramic salt shaker on the edge and chunks of the enamal have chipped out. I was told this is not...
just the angle of the hit, not the weight of the item, granted a very light wieght item is less likely to cause damage but a large spoon hitting at the proper angle can cause this i know i was the one that did it
time for the touchup paint
Apr 21, 2008 | Kitchen Ranges
Kitchen Ranges Logo
215 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
