Question about Kenmore Elite HE4 Electric Dryer
Won't power on
I have a HE4 Electric Dryer. I had turned the house circut breaker off to the dryer, and when i turned it back on again the dryer would not turn on. I get no lights what so ever. I have checked conductivity and am getting power to the board but that seems all. Help please
thank you Same issue. Light inside comes on when I open the door but no digital displays are functioning at all. If you solved this please let me know,
Thanks
    Problem Solver:
  • 14 Answers
Whoa whoa whoa... stop.
when a dryer turns off your house breakers it usually means there is something wrong in the curcuitry. Have a electrician come to check your house breakers.
Make sure your dryer is rated for your power supply 120, or 240 volts. Is the amperage correct?
I have seen some guys wire thier own 240, and sometimes the wires are backwards on there or they cut out the ground wires. A licensed electrian should come to check this out.
please make sure a licensed electrician comes to your house quickly and check things out. Then go from there.
Posted on May 20, 2008
  • 24 Answers
Door switch bad.. bad connection it sounds like.. check this out too.. mine goes dead once in a while or does the triple beeping and this is what cures it every time..
http://www.youtube.com/watch?v=tq3k22cqjR8
Rob
    Problem Solver:
  • 6 Answers
U have only 120 vac, need 240 vac. Turn the 30 amp breakers hard to off then back on. Should do the trick
Posted on Apr 29, 2008
Kenmore elite he4 moder 110 won't heat
In terms of likelihood, here is what's wrong:
1) The heating element has failed.
2) One of the several "overheat thermostats" has overheated and failed.
These are found in the back or the bottom of the dryer in the rear.
3) One of the wires to something, like the heating element, has burned in two.
4) The panel where the electric cord attached to the back of the dryer has failed. This will be inside the back of the dryer, usually behind a small plate.
5) The circuit breaker for the "heating" circuit wire of your dryer is popped and needs to be reset. (That is the circuit breaker found in your hall, or basement, or garage, or wherever.)
If you decide to fix it yourself, a question to "fixya" might get you step-by-step instructions.
Be blessed
4)
Feb 11, 2013 | Dryers
I have a bran new Admiral dyer that won't work
The dryer may have been wired incorrectly, e.g., 115v rather than 230v.
May 23, 2017 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Kenmore elite he4 blows circuit breaker
your element or motor has shorted as these r the only components that r earthed within the machine so check these first
Nov 10, 2011 | Kenmore Elite HE4 Electric Dryer
Doesnt dry clothes, every opening i have unclogged,even outside vent is clear.basket rolls but heat is room temp. no matter what setting.
Hi, I experienced the same problem with my Maytag electric dryer. I finally fixed the problem after I checked the actual vent pipe (which allows air to discharge to the outside of your home). What I found was quite surprising. I found was a mouse nesyt in this pipe. Once I removed the mouse next,m my electric dryer worked fine. Just a thought. Good Luck!
Jan 09, 2011 | Roper REX4634KQ Electric Dryer
By mistake i hit the circut breaker and since i put back, the dryer does not heat up. only cold
Hi, Sometimes the circuit breaker will not reset properly turn it off again and reset it hard.... If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Dryers
My dryer model kenmore 110.85862400 has power but does not turn on...is it possible that I locked it somehow? Do you know how I can unlock if thats the case. Someone told me to check fuses or breaker as...
Faulty door button or faulty thermo cut out located on the heater housing Check for oms Door switch when pushed in and thermal switch when power is applied
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
94 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
