Question about Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas
Not working the heater starts up OK and works for a few minutes then it cuts out and the number 12 comes up on the digital display. then when i try ot turn it on again, it just clicks and clicks and clicks but won't start. if i leave it for a while it will turn back on but then it just cuts out again.
  • 1,420 Answers
Code 12 is a gas supply error code or an ignition failure. There is no pilot light in this unit. I would suggest you get a technician in and have him/her inspect the burner tray for a buildup of spider webs or other debris. To do this you will need the burner assembly removed from the heater which involves a number of other parts to be removed first.
Posted on May 16, 2008
    Scholar:
  • 41 Answers
soleman13au
Rank:master_s.gif Master
Rating: 90%, 19 votes
Hi lisarinnai
I am assuming it is a Natural Gas Heater. All it probably needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this. Hopefully this should solve the problem. You may want to clean the inside of the heater out as well which mean removing the covers. They tend to get a lot of dust and dirt inside them which doesn't help either. You will just need to follow the screws to establish how to get the panelling off to reveal the inside of the heater. Hope this helps. Regards Bryan
Posted on May 07, 2008
Atwood 6 gal w/h won't stay lit longer than 12 minutes
After it is stored for the 2 weeks, do you turn water on to it, then bleed out any air through the taps before lighting it? If not try that and see what happens and let me know if any different.
Mar 14, 2010 | RTO Atwood Water Heater - 6 Gal LP
Display cuts off. Shutdown computer and it comes back.
your lcd inverter circuit fail
replace ccfl bulb inverter pcb
you can buy it from market with part number
Mar 10, 2009 | IBM ThinkPad T40 2373 Notebook
Hi - I have a Rinnai Convector 406 gas heater which is 2 years old. Yesterday, it started cutting out with an error code of "12" showing in the display. It can be re-started but only stays on for a few...
I believe the 12 is the error code for "incomplete combustion". In this case you will want to start with the thermocouple. If you are not handy at these things I would call a service tech. You can find a service person on their website.
http://www.rinnai.us/
Jun 15, 2008 | Rinnai Heating & Cooling
Sound cuts out every so often when using Coax Digital In
DI cables have little end caps, make sure they are removed
Mar 04, 2017 | Audio Players & Recorders
solution to Both our problems is this, call Philips, "it just so happens that we have a rapid replacement program for this particular system"-"there seems to be an internal electrical problem", so I'm sending it back to them.......
Dec 12, 2007 | Philips HTS-3555 System
Zanussi FJR1454W
It's your circulation pump!
Nov 19, 2007 | Washing Machines
Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas Logo
140 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
