I just bought a new Samsung 953bw monitor at Office Depot. I plugged it in and connected as per directions in the Quick Setup Guide. I placed the cd in the cpu and the monitor doesn't turn on. For some reason, though the box was factory sealed, there was no user's manual included, so I don't know what to do. Can you help me??? Thanks. Jana West
  • 56 Answers
Sounds like the monitor is bad. Does the power light turn on when to press the power button or make a sound?
Posted on Apr 29, 2008
I bought the samsung ipolis at a rummage sale. The picture shows everything I got. So what do I hook it too since those are all the partd I have9 I have
PDF]Quick Network Setup Guide - SamsungSV :: Samsung
www.samsungsv.com/Download/SDE-5003-Network-Setup-Guide.pdf
Internet connection setup method and steps may differ from routers, check your router'ssetup method. ..... More specific information is in "iPOLiS DDNS Setting".
Aug 25, 2015 | Samsung Televison & Video
Power light will not come on. It is pluged in and has power.
Look for bad caps with domed tops, and should replace them in a set.
http://lcdalternatives.auctivacommerce.com/Repair-Kit-Samsung-SyncMaster-953bw-LCD-Monitor-Caps-P1660391.aspx
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 18, 2011 | Samsung 953BW LCD Monitor
I have a Samsung monitor, model #953BW. I put the computer to sleep last night and this morning the monitor will not display anything. It is the monitor, not the computer, as another monitor works on that...
At this point you need to open up the monitor and inspect the inside.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 06, 2010 | Samsung 226BW Monitor
Samsung syncmaster 953bw
Oct 23, 2009- This is how it went for me..I have a Samsung SYNCMASTER2.gif 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. Oct 23, 2009- I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
Sep 26, 2009 | Computers & Internet
Unable to get Samsung monitor 953bw to 1440x900 resolution. The option doesn't get displayed in graphic properties window.
Dear,
Sea u r Display properties, wether u have installed a right VGA driver. If u have installed right one please install new version of the sa,e.
Cheers
Jaggu
Sep 21, 2009 | Samsung SyncMaster 953BW 19 inch Monitor
Monitor turns on for less than a second, then off. I bought a 19" Samsung LCD monitor (953BW) about 10 months ago and the first time I used it, it would only switch on for a split second and shut down. ...
Although the OP was 2009. I had this problem.
I simply replaced the power board. Which I bought from ebay for $20AUD.
It was real easy to remove as well. Just have a look for youtube videos.
Fixed!
Aug 31, 2009 | Samsung 953BW LCD Monitor
Samsung 953BW blue power lights just flashes when turned on nothing visible on screen with no computer connected
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 31, 2009 | Samsung 953BW LCD Monitor
CANT LOCATE CORRECT CHARGER
Howdy,
Most office supply stores and home supply stores, Office Max, Office Depot, Staples, Home Depot, Lowes, carry a Universal AC Adaptor that has multiple voltage settings with multiple plugs that fit a variety of low voltage charger connections.
Dec 11, 2008 | Peg Perego 12 Volt Rechargeable Battery
Computers & Internet Logo
David Payne
David Payne
