Question about Kenmore Elite HE4 Electric Dryer
Electric kenmore dryer
When start button is depressed the motor runs, when the button is let go it stops instantly. I think that explains it in a nut shell. push button it runs, let go button it stops. thanks for any help
  • mimmoe May 13, 2008
    First, I want to thank you for getting back to me. I had a tech come out and he said it was a faulty circuit board, about 4"x5" at a cost of $95 for board alone. With the answer that you sent especially about the switch, it just makes me wonder about the circuit board solution. Oh well, sorry its just my suspicious nature about some service buisnesses. Again, thanks for your info, it was truly appreciated!! PS maybe this will help the next person
Service tech came to the house to fix it and discovered it was the relay switch, not the circuit board like the previous tech said and ordered the board which took a week. Anyways the relay switch did the trick. I hope this saves the next guy some trouble. Thanks
Posted on May 21, 2008
  • 1,073 Answers
Replace the motor it is stuck in the start winding and can cnot get up to the run winding as long as you are holding in the start button the start winding is working in a second it should through the motor switch shift the voltage to the run winding
bad motor switch
replace switch if available or change motor
Posted on May 11, 2008
How do I know if motor is bad on a kenmore 90 series dryer
you have reassembled it incorrectly and now the motor cannot drive the drum
Nov 25, 2017 | Kenmore 62602 Electric Dryer
Kenmore dryer model 110 66862501 stopped turning, when I depress the start button i can hear it want to run, but when i let go of the button the motor stops, could it be a belt?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jul 18, 2011 | Dryers
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Kenmore dryer only runs while start button is depressed. Timer ? Thermostat ?
Centrifugal switch on the motor. Either the switch is bad or te motor is not turning fast enough to engage it.
May 19, 2010 | Kenmore 62882 Electric Dryer
Kenmore 70 series dryer will not start. When starter is depressed there is a sound like something is trying to engage but will not. Then we detect the smell of electrical burning. After a couple of tries...
Hi, It sound's like your dryer motor is cooked. Before you give it the last's rights, it could be something jamming the motor and preventing it from starting...though that usually won't cause them to smoke which would produce the electrical burning smell, just stop via the overload device. Time to unplug the unit and dig into it. If you feel capable, if not call in a pro. I would try to confirm the motor problem first it may be just as worth while to buy a dryer depending on the age & condition of your's. The motor's alone can be quite expensive. Hope that help's move you forward at least. Good luck. Macmarkus :)
Dec 13, 2009 | Kenmore Dryers
My Kenmore dryer "Start" button does not stay depressed.
a complete model # from inside the door would be helpful, on wost dryers when this occures the motor is packed with lint so the sentrifisle switch cant move from the pastion to the run or the switch on the motor itself is bad, the run windings in the motor could be bad. some of thethe more complicated dryers have a relay on their control board than burns out. try blowing out the motor with compressed air or the blow end of a shop vac use the skinney attat. to concentrate air
Dec 08, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore 110.96588210 Electric Dryer
you can take the top panel back off and check the start button with omes meter,push button in you should get a reading,let button out no reading ,if it fails the test replace,let me know what you find
Sep 22, 2008 | Kenmore 62602 Electric Dryer
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dyer
sounds like the timer, unless it has a Evenheat contol board and a seperate motor relay, in which case its most likely the relay, or could be the computer
Sep 29, 2007 | Kenmore 64892 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
113 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
