Printer cord the part of the cable that goes into the printer won't fit. i am using a universal printer cable, and it seems to be too big. a friend told me that all printers use the same end pieces, but that there are smaller ones for mpv players, camera's, etc. it is a pretty small printer, so do i need to pick up a small one?
  • 85 Answers
Hello shepardlab,
try this link to pin point your usb 2.0 cable
Posted on Apr 29, 2008
  • Cnythia Miller Apr 29, 2008
    shepardlab,
    Check here
    shows long flat end to usb of computer and small square to printer.
My friend is having trouble with his car......this what he posted on facebook So update. BRAND NEW BATTERY AND STARTER. Autozone diagnostic rules out alternator. Car refuses to start, no lights no...
wires on starter motor fitted incorrectly the thin wire goes to top lucar type connector and the big heavy cable goes to the big upper terminal on the solonoid its fitted to the bottom one by the sound of it causing the engine to turn as soon as power supplied
Dec 17, 2010 | 1995 Pontiac Grand Am
NEED A REPLACEMETN POWER CABLE FOR LEXMARK 640 COLOR JET PRINTER
If that is a T640 printer, it uses a standard computer power cord.
Any one will work, but if you can get a right angle plug on the printer end, it will look and fit better.
NOTE! If you get a right angle plug, make sure it bends the correct way (the plug only goes into the printer one way, and if the plug bends the wrong way it won't fit).
Mar 11, 2010 | Lexmark T 640 - printer - B/W - laser
Brand new brother HL-2140 get service call error (all lights flashing for more than 10 minutes). First time to setup. Don't know how to proceed.
You should have a manual with your new printer, please read it before doing anything with your printer. I'll try my best to show you how to set it up properly for the first time. Make sure to plug the right cable at the right place. There should be 2 basic cable for your printer to work properly; the power cord and the USB cord. Power cord is thicker than the USB cord (black). One end goes to the printer and the other to the power outlet. The USB cable is the data cable of your printer (white/transparent). One end should go to the printer and the other to the PC. First, plug the other end of the USB cable to the printer and the other end to the PC. Next, plug in the power cable to the printer going to the power outlet. Press the power button and you can now use the CD that came with the printer to install the driver. If the lights still persist, then check the toner and the tray. It should be properly fitted inside. Also check the paper, there could be a paper stuck inside.
Hope this helps . . .
Nov 08, 2009 | Brother HL 2140 Laser Printer
What is the power cord specification for the Konica PapePro 1350w A friend gave me the printer and she can' t find the power cord
It will work with any standard power cable, a PC power cable will be just fine, just check the connector to fit properly.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Jul 19, 2009 | Konica Minolta PagePro 1350W Laser Printer
Has a cord that has the same type of connection on both ends
Look on the back of the emachine, there should be a blue connector with 15 holes in it. Thats the VGA connector and thats where the other end of that cable goes.
May 31, 2009 | E-Machines eMachines Desktop PC
Yellow input/output cable broken off in TV
you can use a screw small enough to fit in the middle of the tip of the cord.the tip is hollow so just remove any plastic or hard rubber that is clinging on the said tip.(use a big needle for this.)be careful when doing this.make sure that the unit is turned off and unplugged.after inserting the small screw,slowly twist and try to pull it gently until the screw is tight enough but not breaking, to pull the tip.
May 12, 2009 | JVC Televison & Video
Got a printer from ebay dont know how to set it up
You need a USB cable to printer. The USB end is about 3/8" by 1/8" (flat rectangle), the other end fits a port on the printer.
Mar 11, 2009 | Dell 725 InkJet Printer
Cant find usb cord to fit my Epson NX400 inkjet printer
HI!
There are universal cords to buy, the important is that you know the Voltage and the Ampere so you get the right one. To get the right Voltage and Amphre look in your manual.
You can find and order a universal cord from the ner or find one in a good electrinic shop
Good luck
Nic
Mar 04, 2009 | Epson Stylus NX400 InkJet Printer
My usb cable dosent match the port in the back of 5300
Usb cables are universal, the only reason it may not match is if the MAN. sent the printer with it's own cable. That would not seem to be a Canon thing to do if it were a Dell then yes.
Also, try this the USB cable will only fit in one way, try turning it the other way and see if it fits. the silver end part has a line down the middle that part should be in the down position.
Jan 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I'm not sure if I have the correct cord or if I have it pluged into the correct port.
It is either a usb "A" connector which is the squarish side of the usb cable and the flatter "B" connector is the side that goes into your computer's usb jack. Some printers, like yours also still use a parallel port which is a Centronics big, wide rectangular connector that connects to the printer side and the other end is a DB25 parallel connector than goes to the parallel DB25 printer jack on your computer. You must have at least one of those cables but you only use one or the other. The usb will be configured to a usb local printer port or the parallel will use the LPT1 port. HP.com will provide you with a quick install brochure with pictures for you to see. post back if you need more help! Steve Medley
Oct 21, 2008 | Office Equipment & Supplies
26 people viewed this question
k24674
jasbo
jasbo
