Question about Toshiba TEC B-SX4 Thermal Label Printer
I have a TEC SX4 printer and im trying to convert the machine to print on thermal labels without a ribbon.. I don't know how to do it! Can anyone help me please
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
Quite simple.
- Remove the ribbon
- in the support tab of the driver select direct thermal.
- Send a test print to the printer.
It's done
Posted on Jan 14, 2014
SOURCE: Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
Posted on Mar 21, 2009
  • 19 Answers
SOURCE: Ribbon spool does not turn, TEC B452
If you are working with the driver, change in stock page direct thermal to thermal transfer.
Posted on Mar 26, 2009
  • 254 Answers
SOURCE: TEC B431-GS10 problem- Print-out in labels are only half
Various possibilities:
- The data cable on the head is not correctly inserted.
- the head is out of order.
- You are printing with a driver with a lower graphic resolution than the head resolution
Posted on Sep 02, 2009
  • 254 Answers
Switch the printer on with the buttons feed and pause pressed.Press feed to display Sensor adjust. Press pause until transmissive is displayed. With the liner in the cells press on restart until a star is displayed next to the value (around 4.7V) press Pause the calibration is finished. In my opinion, you should check the size of your label and the distance between the labels (label gap) and also check that you have selected the correct detection (Transmissive for gap or relective for black mark)
  • 4234 Answers
SOURCE: Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Posted on Apr 22, 2010
How to change from Thermal Transfer to Thermal Direct on Toshiba TEC-SX4
Hi Ryan, refer to sections 5.2 Overview and 5.3.1 Printing Mode Selection from the following pdf manual. Hope this helps.
May 20, 2014 | Toshiba TEC B-SX4 Thermal Label Printer
Ribbon error problem for Toshiba TEC B-SX4 Thermal Label Printer
Calibate the detection value and check the rbbon motors values
a sammler ribbon could need some adjustments
Mar 27, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Smartforms printing to TEC B-SX4 in SAP
this may be because the instructions are truncated.
Check by using the dump function on the machine
Dec 07, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
How to print label on b-sx4 label printer
You must use the option send file to printer in the seagull driver not print else it is converted to graphics and sent to the printer.
May 16, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Printer SX4 - Just changed Head, When printing the head is rubbing on the ribbon causing streaks on labels, the leaver is in the right posistion too.
Need to use the correct Ribbon.
It's near edge head technology. Do not use ribbons for flat head technology and yu'll have less problems
Apr 28, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Printer printed 5 tags but there is wrinkles in the tags so i tried to realign the ribbon and now it will not print
Ribbon wrinkles are due to:
- Ribbon too large.
- Print Head misaligned.
- To much heat.
- innapropriate Transfer film.
check with your tag dealer
Apr 24, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Hi, I have a TEC SX4 printer which im trying to
There is usually a setting in your label software or printer driver that lets you choose between thermal transfer printing or direct thermal printing. Make sure your setting is on direct thermal.
Hope that helps !
Aug 12, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba TEC B-SX4 Thermal Label Printer Logo
Top Toshiba TEC Office Equipment & Supplies Experts
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
