I need to locate a Compaq adapter; Series PPP012L Compaq Part # 239428-001 (old adapter says to replace with Compaq Spare #239705-001) I have looked online and can not find an adapter with these ID # 's
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    adapter..as in power adapter?
  • 52 Answers
Power problem power is not on
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, your compaq f500 power adapter is probably faulty and needs replacement.Hope this helps.
Jan 30, 2013 | Compaq Presario F500 Series Laptop...
WILL NOT TURN ON
check your outlet of your power and check your cable if they are okey..sometimes some of the cables has a problem on it. If you have a spare cables ..try it first.
Sep 17, 2011 | Compaq Presario V3500 Series Laptop...
Can this HP Pavilion DV9000 laptop adapter fit for Compaq Presario V3000 laptop? I doult that HP Pavilion DV9000 laptop adapter on website:http://www.laptopbatteryshop.ca/hp-pavilion-dv9000-ac-adapter.htm...
Have a look at the label on the bottom of the V3000 laptop and check the voltage and amps power rating of the laptop.
If the DV9000 adapter has the same voltage and current rating (amps) or higher amp rating then it is suitable for the V3000 laptop, provided the power plug fits the V3000 power socket.
Jan 15, 2010 | Dell Inspiron 1525 Laptop
Is this model wifi enabled
You have not given your laptop specific model number! In any case, the Presario 2200 series of laptop normally come with Wifi adapter as standard. To check, use windows 'Device Manager' and locate the 'Network adapters' node: this will tell you for certain what network adapters are available.
Hope it helps. Let me know how you go or if you need further assistance.
Jan 08, 2010 | HP Compaq Presario 2200 Notebook
I have problems with my desktop and was going to use my old Comapq Presario until I can get the desk top fixed. How can I hook that old laptop up to the internet. All I see are dial-up options
you will likely need to add an ethernet interface / network card. If you have a spare USB port, then use a USB Network adapter. If not, then you will need to use a PCMCIA (aka PC Card) network adapter.
Nov 02, 2009 | Compaq Presario 1700 Notebook
Compaq fs7600 needs new network card
The network card can be purchased online for apx. $10.00, yes she can replace the card easly, have her open the computer case with the computer turned off and the power cord unplugged. Locate the old pci network card, remove the screw holding the card, pull out the old card and insert the new card, put the screw back in, plug in the power cord and connect the cat5 cable, restart the computer. The found new hardware wizard will find the new network card, insert the CD that came with the new card and following the instructions on the monitor. BPCS
Dec 29, 2007 | Compaq StorageWorks FCA2354 Network...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
