My microphone headset volume is too low.
I have conexant hd audio and it isnt compatable with the mic boost (20db).
Is there any other way to make my microphone louder?
(im trying to use it for voice recognition)
  • errorguy May 11, 2008
    Thank you for the help but ive already tried going to mic properties but my sound part doesnt support sound boost (there is no levels or advanced tab). I was just wondering if there was any program or other way to boost my mic.  (and im fine if there is no easy solution because i have actually just given up on voice recognition)
  • Anonymous May 05, 2009
    Mic boost IS NOT THERE.
  • 111 Answers
It should be able to suppor 20db boost. the way to enable it is just different. Try this: Right click you speaker icon in the lower right side of your desktop and select Recording devices and highlight your mic and click on the properties button on the lower part of the sound window and a new Mic Properties window will open. Select the levels tab and change the Mic boost from there.
hope this helps.
If it does, please vote. Thanks!
Posted on May 01, 2008
I received my Asus HS-101 PC Headset today and plugged them in - I can hear sound though the microphone doesn't work for some reason. Any ideas?
You plugged both the headphone part in and the mic part in separately, right?
If you right-click on the speaker icon, you can select the "recording options". There may be a checkbox for "+20db" for the microphone as well as a volume slider. Try both.
May 14, 2015 | Radio Communications
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
I have been using Plantronics 995 for several weeks. I quit working without any system cnanges. Have tried re-paring, and reset all audio settings to plantronics. Bought replacement unit ( plantronics...
this is a normal reaction ..specially on a wireless device ..the idea is to lower the volume into the computer ..(to max 80%)..and also get into the volume control by double clicking on the speaker icon in the task bar ..and in here look at the mic volume
if there isnt any volume section for the mic..than click options ..than properties..and from the list tick the case for mic in ..and will list the volume for mic..
if the advanced function is on ..check into the advanced under the microphone it is started the mic boost function ..if it is ..and you want to keep it for a better mic reception ..than you have to put the mic on mute to eliminate the static noise..
THis should not mute it for good..but you can make a trial to be sure..
If the advance boost function is on ..and the muting puts it out for good..the choice is to get rid of the boost but usually works if you mute it ..cause only mutes the noise ..
let me know if you didn't understood anything ..
Sep 03, 2010 | Plantronics Radio Communications
I have a gateway notebook 3 yrs old, when on skype i can hear voice they can not hear me is this my sound card. sometimes they can hear but not all the time
gharris_hig
Most likely you will need to toggle the mic boost. The below steps with help you do this.
1. Click START / PROGRAMS / ACCESSORIES / ENTERTAINMENT / VOLUME CONTROL.
2. Click OPTIONS / ADVANCED CONTROLS.
3. Click ADVANCED below the MICROPHONE slider.
4. Toggle the MICROPHONE +20dB BOOST option.
5. Click OK.
Issken
Dec 30, 2009 | Gateway Sound Blaster CT4870 Sound Card
I have a compaq presario v3700 with windows xp.It has conexant high definition as audio. I plug in my headset. It works in terms of audio hearing on headset but u can also hear it on computer. Then my...
Don't think its the drivers, because you can hear audio.
Do you have your mic with your headset or separatedly? If with headset, maybe your headset has a physical switch where you can enable/disable mic (seen this feature on some Locitech headsets).
You can also check whether you have Mic muted in your audio control panel. Go to Control Panel, open Sounds and Devices and File - Properties if I remember correctly (sorry, I have Vista now) and put a check before Mic property to bring out the Mic volume level bar to see whether it's muted or not.
Hope this helps,
Tom
Nov 17, 2009 | HP Pavilion dv9000z Notebook
Headset mic won't work.
What have you done to try to fix it I need to know so I can help you fix it and Mabry you need new headsets
Nov 18, 2017 | Logitech (980158) Headset
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Microphone Dell Inspiron 1100
my microphone is working but it cannot pick what i say.also i have only one green port for speaker. i need helpto get it to pick up what i say
Oct 30, 2007 | Dell Inspiron 1100 Notebook
Problem recording when connected to computer
In the volume control panel look for mic boost and tick the box to boost the microphone volume. It's under options properties/Advanced controls etc.
Apr 13, 2007 | Sony One-Point ECM-MS907 Consumer...
Computers & Internet Logo
411 people viewed this question
David Payne
David Payne
