Question about Samsung TX-R2435 TV
Samsung TV Won't Turn Off
I have a Samsung TV that will not turn off with the remote or manually. It started a few days ago and I can lower the volume only through my VCR. Model numbers on my manual are SAMSUNG TX-R2 735, 435, 728, 734. I haven't tried to unplug it because I'm afraid it will not turn back on.
  • 71 Answers
If this set has a power relay the contacts in the relay are welded closed; unplug set for 10 seconds and plug back in; it will probably come streight on if relay is stuck. replacing relay will fix if this is the case
Posted on Apr 29, 2008
My samsung tv model#LN52B530P7FXZA volume doesn't work, remote wont turn tv on
If you can manually turn on the TV and manually adjust the sound, then the remote is your problem. Get a new remote.
Jan 12, 2018 | Samsung Televison & Video
40 samsung lcd tv problems
remove batteries from remote control and adjust volume to desired level. If the volume stays the same then there is a problem with the remote. If the volume lowers again then the problem is with the TV. the volume button on the TV or on the remote may be malfunctioning. Hopefully it will be on the remote. If it is the remote, take it apart and clean it with damp cloth. after allowing it to dry, re-assemble and try it out.
Sep 12, 2013 | Televison & Video
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
My remote has a long delay on the up and down just started a few weeks ago and im getting annoyed..Common problem?
Manually turn the volume knob on the receiver several times as to loosen it up. Change the batteries.
Feb 25, 2011 | Onkyo RC-375DV Remote Control
Our 52 inch samsung plasma tv makes a humming sound when on. is this dangerous. comcast said it should not be happening
Try this.....
Turn cable remote volume all the way down. Raise the volume all the way up with your TV remote. Lower the volume with Cable remote to your usual listening volume.
Feb 12, 2010 | Samsung DLP HL-P5663W 56" TV
Remote wont change the volume... Zone 2 problems...?
you have to turn off zone 2 it mybe on the back of the remote unit the door after you do so the master volume will work
Aug 23, 2009 | Denon AVR-2308CI
Samsung remote won't turn 630 LCD off. Only volume works.
yo moel
the way i did it was take the batteries out and hold powere button for 5 seconds put batteries back in and should be fine mate!
Dec 25, 2008 | Samsung BN59-00599A Remote Control
Volume on Remote powers TV on and off?
This unit has upgrades available for this set. I am not at my shop now, but, I think the problem you described is usually cured by this upgrade. The set is under warranty, contact: 1-800-Samsung for a local servicer. If you need additional help, respond to this post and I'll reply.
Aug 26, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung TX-R2435 TV Logo
2,901 people viewed this question
Jerry Greenberg
Jerry Greenberg
