Question about Motorola Mobility H500 Wireless Headset
Motorola headset bluetooth h500
My device starts well, but disconects and connects alone, also I can start calls but it drops. and I can't end calls whit the call butom
  • daveyjones19 May 08, 2008
    I have a similar problem. Mine starts up and connects fine but within like 20 sec it disconnects? My phone is a LG chocolate
I can not ear auido in my head set
i installed software than i connected my device than i can"t ear any sounds on my headset
Posted on Jun 10, 2008
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Oct 31, 2016 | Computers & Internet
ONLY GETTING LIGHTS AND FAN TO COME ON
if there is no "beeps" probably PSU or MBbut try next... disconect RAM, HDD, optical drive and any PCI devices you have... if here is still no beeps it is what I said, PSU or MB. if it starts beeping put RAM in, if there is no beeping and it wont start then you have a bad RAM. ofcourse anythig you change (disconecting/connecting any PC device, PC must be OFF)
Nov 04, 2012 | Compaq Presario 5000 PC Desktop
In the last 5 weeks the car engine has cut out 3 times so i have had to disconect the battery then connect it back after 1 minute then it starts back up.
the problem is the imobilizer that needs to be changed. sometimes, probably because you leave the key in the ignition whit the car stoped, and go out for a few minutes, it arms the imobilizer and then you only will fix it if you turn the batery off.
Mar 21, 2011 | 2006 Volkswagen Passat
When you open the door, the window drops a little and doesn't come back up until door closes normally, but my problem is when i open the door the window drops a little like its supposed to but instead of...
You may need to store the end position of the windows in the control unit. I would try the following, with the door closed, and the window partway open: Close the windows with the rocker switch ONCE. Then press the front half of the rocker switch again, this will store the end position in the control unit. Good luck!
Oct 18, 2010 | 2001 Porsche Boxster
Not heating
few supoeses:
1) wire disconected; = repar and isolate;
2) presostat damaged; = replace whit similar new one;
3) heating element intrerupted; = replace whit similar new one;
4)presostat damaged = replace whit similar new one;
5)saftey thermostat ocured = rearm the saftey thermostat and check whay that ocured (setings, sorts, .........)
Feb 23, 2010 | Dishwashers
I recently removed my battery to prevent a theft i replaced the battery now every time i place it in park, or nuetral, it stalls, although re starts immidiatly soon as i put in park and turn the key...
HI disconect battery cable and recconect start engine let it idle for 10 minuts do not touch gas peddle let it relearn idle strategy if this doesent help try cleaning throttle plate by using carb cleaner or the special cleaner whit engine of open throttle spray cleaner using a tooth brush scrub throttle plate till clean
Dec 01, 2009 | Dodge Ram 1500 Cars & Trucks
Power butom keep flashing
I've came across this problem before but there was no affect to the tv. I have also been told that it is a warning but for the most part we dont know what kind of warning that could be. If this is not affecting your tv in any way then just let it be. But if it affecting your tv call your tv manufacturer as soon as possible to see if you are still within warranty to receive a replacement.
Aug 04, 2009 | Philips 42PF9631D 42 in. Plasma Television
Garmin 760 will not disconect from phone call on bluetooth
i think this is a fimware fault.. do a firmware update this will get solved..
Mar 30, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Motorola Mobility H500 Wireless Headset Logo
75 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
