Question about Maytag Refrigerators
The climate zone drawers are not reaching the desired temp on the Maytag frig. Also it seems the fan on freezer side seems to keep on most of the time.
5 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: frig and freezer warm most of the time
HI thanks for your question, i think what your problem is . the compressor is over heating and cutted out. clean all the coils at the back of the fridge. if theres a fan motor at the back make sure its going check that thanks
Posted on Oct 17, 2008
abhishek33
  • 1239 Answers
SOURCE: Frig warm, Freezer Cold
Hi friend
it is nothing but thermostat(black heat coil) problem please check it
thank u.........
Posted on May 03, 2009
SOURCE: Freezer not maintaining temp
sounds like the evap thermistor took a ****. in the back of your freezer you have cover that sits over the refrigerator coil. under this coil sits a heater element that is turned on and off to defrost the refrigerator coil based on how long you've had the door open. the evap thermistor reads the temp inside the freezer.. close to the refrigerator coil.. and tells the heater element to turn off after it reaches a set temp where it can be sure that the ice has melted off the refrigeration coil which is about 60 deg. if your thermistor has taken a ****.. your heater element will only shut off based on the "fail safe" time (which is based on how long you've had your fridge door open) leading to a hot freezer.
i suspect your at home more on the weekend.. inside the fridge.. getting cold beers.. and that is why it ends up hotter on the weekend.
Cheers!
Posted on Aug 07, 2009
SOURCE: Maytag Model MZD2768GE
I've got the same problem with my 2nd drawer. Did you figure out the problem with your top drawer?
Posted on Jan 20, 2010
Maytag climate control drawer fan is not running.
Refer your inquiry directly to Maytag or an appliance parts supplier.
Jun 28, 2014 | Maytag MZD2766GES Side by Side...
Refridge is warm, freezer is working fine. There is a damper controlled by a small motor behind the meat drawer or top drawer. Pulled out drawer, and hole that gets air from freezer was blocked with a...
This is known as the CZT or Climate Zone Technology fan and if you direct wire it and it does not run, replace.
This is the cold zone fan which supplies cold air to the meat and crisper drawers.
Feb 07, 2011 | Maytag MSD2758GEW
OK, here's the problem - Samsung model RB1955SH - plug refrig in it cools both frig and freezer to desired settings - however, once system reaches stttings and turns off compressor, will not restart system...
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Jan 18, 2010 | Refrigerators
Temperature going up on freezer and frig overnight
The Unit has a defrost cycle either every six,tweelve,or twentyfour hours.It sounds like the thermal cut out is faulty located in the freezer side behind the wall where the fan is situated It is usually a steel round disk shaped sensor with two wires coming out of it.It,s purpose is to shut the power off to the defrosting element once it reaches the desired temperature to melt the ice away and them the unit cycles again after defrosting.Hope this helps.
Dec 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
MSD2758GEW Climate Zone Drawers
This fridge is garbage. Fixed ours 14 times in 6 years. WILL NEVER BUY ANOTHER MAYTAG ANYTHING AGAIN!!!! CLIMATE ZONE TECHNOLOGY DRAWERS NEVER DID WORK CORRECTLY....EVER.
Jan 31, 2009 | Maytag MSD2758GEW
Too cold in frig
Check for a faulty thermostat it is responsable of shutting down the compressor when it reaches your desire temp.
Jan 19, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
I have a fairly new Maytag frig with bottom freezer which cools well but I can't seam to change the temp and more importantly, a lot of fog comes out of the frig port, the frig and freezer seam to have...
hi thanks for the question if you have fog coming out of fridge it sure is cold enough you must live in a very hot climate i wouldn't worry at all thanks the appliance doc
Sep 24, 2008 | Maytag Refrigerators
FREEZER NORM TEMP. FRIG. 60 DEGREES.
DEFROSTED COIL WITH HAIR DRYER BEHIND FREEZER WALL BELOW FAN,
REPLACED FRIG. THERMOSTAT.
Aug 11, 2008 | Maytag 21.6 Cabinet Depth Side by Side...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
65 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
