Question about Imperial IFS40 Deep Fryer
Deep fryer My fryer is not kicking on when it should when the temperature drops below a certain level. I have to tap the temp control knob to get it to fire back up. Do you have schematics laying out what the switch looks like inside and do you have suggestions on how to repair it versus spending $300 canadian for a new switch.
  • Anonymous Mar 26, 2014
    I believe the thermostat has gone bad. Could you help verify,
  • 456 Answers
Hey you should have to change the switches only
the same was happening with me and i changed the new switches
Posted on Apr 29, 2008
  • 52 Answers
Well the temperature knob is connected to a potentiometer. you could possibly unsolder it and take it to your local electronics shop and have them match it and then resolder it back on. also check your wiring to see if you have any loose connected wires.
    Master:
  • 788 Answers
If tapping on the knob works then the potentiometer or rheostat that knob is on it most likely the culprit. Replacing it should not be very expensive. You would just need to open up the unit to find out the type and resistance values of the component. You should be able to buy an equivalent part at radio shack or any electronics parts supply store.
    Genius:
  • 3,422 Answers
Please confirm that the model no is IFS40..
Waiting for your reply..
  • Priya darshan Apr 29, 2008
    I'll let you know if there is a service manual available for it.IF the model no. is different let me know..
2 Suggested Answers
bigg t
  • 640 Answers
SOURCE: Commercial Deepfryer
goto this site http://www.3wire.com/foodservice/ sign in and look for your model.
Posted on Dec 16, 2007
B&S deep fryer heats up to set temp..like 170c, then pilot light turns off.try to relit,no good.if i wait10..20min.I can relit it.but when reach temp,flame goes out again.
The high limit is shutting the fryer off. It is auto reset and that is why the fryer works after waiting. It sounds like the thermostat is not shutting off and the high limit is kicking in. You need to check the actual temperature of the oil.
Aug 05, 2016 | Kitchen Appliances - Others
I have a vulcan deep fryer and when i turn the knob up to 400 max it heat the oil but will cut off if i turn down to 375. the unit has been off. what part is needing to be replaced.
I'm unclear, if it has reached 400 you would expect it to be off at 375, until the temp drops below 375.
If I have misunderstood then apologies.
May 13, 2014 | Vulcan EF3 Deep Fryer
Fryer is cutting out after certain temp and tripping hi limit. I replaced Hi Limit, Thermopile and Thermostat and it worked great for two days and then kicked out again, tripped Hi Limit. I'm baffled...
Hi there
Hi limit will trip at 450F.
Check your thermostat setting, then check its calibration, this way you will be able to verify where the problem is.
If the setting and calibration of the thermostat is good, check the hi limit sensing bulb, it should not touch the fire tube because if it does, it will sense high temperature and will cause premature tripping.
Regards.
Jul 11, 2011 | Pitco Frialator SG14 Deep Fryer
Fryer wont lite when temp knob is turned up to 350 range pilot is lit
Observe the thermostat when set to higher temp, you should hear a clicking sound as the mechanical contacts inside closes, at this point, burners should fire up.
Thermostat can be tested by checking the continuity across its terminals (using an ohm meter) when set to a temperature higher than the oil temperature.
Also, the thermopile must be free of soot or any form of dirt and the pilot must have good flame quality, gas pressure should meet the nameplate's requirement.
Jun 09, 2011 | Imperial IFS40 Deep Fryer
When set at 350 surface temp drops to 270 when being used
Oil temperature normally drops when product is loaded especially chilled or frozen products. Oil temperature should reach the set point before cooking time ends.
Jan 15, 2011 | Pitco Frialator SG18S Deep Fryer
High limit kicks out fryer and pilot light can
Since you've mention the pilot light goes out at 400 degree F, then we are talking a gas Deep Fryer. The deepfryer usually use at 350 degree F for chips or else. Because the oil will start breaking down its quantity of frying very quickly over that temperature. Most people set at 350 degree F. Now we comes back to your problem, First you should have a deep fryer thermometer they espcially made for deep fryer, (You only mention 400 or better ) that make me think you're only guessing. Knowing the temperature is very important, most Hi limit is set at 420 degree F.
To me it seen the Hi Ltd control is working and that is why it cutting out the pilot when it reach its limit but we don't know what temperature that when the hi limit cutting out at.
When you have a thermometer, put it in the cold oil and turn the temperature to 100 degree F to see what the temperature control cutting out at. slowly increase your setting until it cutting out at 350 degree F . If you set at 250 degree F and the thermometer already reaching 350 degreen F then don't go any further , your temperature control is defective and need to be change a new one.
This is only the first step, you still have to check out the Hi ltd control to see how good its condition is,so far your information say it cutting out at 400 or better. But you've to be sure, because it is a safety control. Hope that will help you , God Bless.
Jul 05, 2009 | Pitco Frialator SG14 Deep Fryer
The thermostat for a GF28 is a Cecilware L099A or F. It is not repairable, but any reputable commercial parts place should have it available for around $90 US.
May 02, 2009 | Cecilware GF-28 Deep Fryer
Deep fryer
Make the "tap" is to the thermostat, and not the gas valve. If it is the t-stat, try cycling the knob back and forth, low to high several times. This may free up the contacts in the t-stat. But in general, if tapping "fixes" it, you need a new one.
Good luck - Mike
Apr 29, 2008 | Imperial IFS40 Deep Fryer
Wells 35lbs fryer double vat
Hello
This sounds to me as if your thermostat is not cycling the unit off. But I can see a second problem as well there should be a high limit cutoff to prevent it from running on and boiling over. I would check both. The thermostat is the dial or knob to regulate temperature and the high limit is the safty to prevent boil over or run on.
Thanks
Mar 29, 2008 | Wells F-686 Deep Fryer
Dec 21, 2006 | Imperial IFS40 Deep Fryer
Imperial IFS40 Deep Fryer Logo
105 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
starztruck4u
Dan Webster
Dan Webster
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
