FixYa.com
Tags:
Maytag Neptune MAH5500B Front Load Washer
Maytag neptune (by 2 users)
posted by tracep87 on Apr 29, 2008
my maytag neptune front load washer will not dispense cold water. i have changed the water valve and it still wont work. hot water is ok. warm water is hot and cold gives you nothing either on wash or rinse. any suggestions?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 02, 2008
My Maytag Neptune has the same problem. When I start the wash warm water will run in for ten seconds, then it will turn to extremely hot and stay hot. I usually wash on warm and rinse on cold. When I put it on the cold selection, it works. But not on warm. This has happened since day 1, I called service rep. out and he told me that this is how the machine was suppose to work. That there was nothing wrong with it.
Solution #1
posted on May 14, 2008
Not Rated (0)
IFIXALL
Rank:Wiz Wiz
Rating: 84%, 287 votes
Change the water valve again ,you most likely got a bad one.The odds of there being no cold water after a new valve is almost impossible.You can test the valve to make sure its working before you go to buy another one.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
bearing
Sounds like a bearing going... Answer This...
not spinning, not drying
washer is not drying Washer... Answer This...
MAH8700AWW
We were washing a load and the... Answer This...
can someone help me please,,,,,...
the ccu board went bad, I put... Answer This...
Maytab Neptune FL washer
the lights on the panel won't... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
