Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Water isnt draining
I havent used my dishwasher for a couple weeks now. When i get home from work i have a puddle of water on the floor for some reason water is backing up into my dishwasher. When i open the dishwasher its filled at the bottom and it wont drain even f i turn t on the dry mode. what do you think is my problem? plese help
  • vmcanchola May 02, 2008
    well when i put it on the dry cylce it sounds to me that the water is draing into to drain pipes, does that make sence? now the check valve is usually located under the sink on one of the brass piping. is there a certain way the check valve should facing vertical horizontal?
    I appreciate your time vmcanchola
    i did check the drain i took plastic screen off and there was some plastic in there. I think could of been the problem because i put it on the dry cycle and it drained i'll keep you posted
    thank you so much again
    vmcanchola
  • 5,911 Answers
Check your drain line and/or drain pump. The drain line should have a high loop at the point prior to where it connects to your drainage system in order to prevent drain water from the kitchen sink from back flowing into the dishwasher. In addition, most drain pumps have a small check valve that prevents this water from backing up as well. However, if you have something lodged in the drain pump (i.e., a toothpick) it can prevent the check valve from closing properly. This can cause water to back up into the dishwasher. You mentioned that the water will not drain. Is the drain pumping runnings at all? Please post back and let me know.
Posted on Apr 30, 2008
  • Jeff Rockwell
    Jeff Rockwell May 02, 2008
    I've personally seen something as small as popcorn kernel take out the wash pump. Just be careful what you put in the dishwasher and let me know if you still have any issues.
Maytag every couple of weeks i come home with a
You will need to clear out the drain in the freezer under the evaporator to fix this issue. THe drain is obstructed and will not allow the water to drain out as its needed for defrost. Good Luck
Sep 16, 2014 | Refrigerators
Why do I have a puddle under my fridge every couple days but no sign of a drip or leak?
If it is an automatic defrost fridge the it will have a hose draining down into a container under the fridge, make sure it is draining where it should and has,not become dislodged. Some have a small tray with either pipes inside it or an electric heater. Some have a container sitting on top of the compressor, both of these are used to evaporate the water.
check to make sure there are no holes in the water catcher.
if you have an electric heater that is not functioning then the container will be already full of water and at each defrost cycle will overflow onto the floor.
Sep 08, 2014 | Refrigerators
How to determine what is causing my refrigerator to periodically leak water onto floor?
uSUALLY A PLUGGED OR CLOGGED EVAPORATOR DRAIN LINE IN FRIDGE OR BAD DOOR SEALS WILL ALLOW MOISTER ANS AIR TO CONDENSATE AND MAKE THE WATER PUDDLES
May 26, 2014 | Jenn-Air JFC2089HE French Door...
My Bosch dishwasher is not draining water and thus leaking on the floor. It is 7 yrs old but only has been used for 3 yrs as I was away. It was run weekly in my absence. Any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 07, 2010 | Dishwashers
PUDDLE OF WATER ON FLOOR MAINLY AFTER WASH IS
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 15, 2010 | Dishwashers
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Small puddle of water won't drain
make shure the strainer is clean
there could be a partial blockage in the pipe
make shure the drain pipe isnt kinked
Mar 18, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Dishwasher drain hose cloggs every couple weekes
Do you have a water softener installed in your home and is the water coming to the dishwasher at least 120F? I have some advice you can read about on dishwashers but it really sounds like a water temperature is.
http://tclaundryrepair.com/home
Feb 25, 2009 | Dishwashers
I have a Rca Refrigerator...Freezer on top and fridge on lower half...I noticed a puddle of water a couple of months ago on the floor under the fridge on the linoleum floor..I mopped it up and this...
HI. thanks for your question. the problem is with a clogged drain tube, located under the freezer. and goes down to the drain pan. to repair. turn fridge off for at least 24 hrs. use a small plastic hose . go to the drain hose, by the drain pan. push small hose inside the drain tube, up as high as you can. now blow in the tube to clear. thanks the appliance doc. please rate my answer thanks.
Oct 08, 2008 | Refrigerators
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
184 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
