Instructions on programming a Randall 102E controler on our central heating system please.
  • moyov2002 Feb 01, 2009
    i am looking for a Randall 102E user manual
    Scholar:
  • 149 Answers
Here's some links to some pdf files that can assist you
http://www.bhl.co.uk/uploads/article331/Danfoss_CP715.pdf
http://www.plumbnation.co.uk/site/danfoss-randall-102e5--24-hour-gp-mini-programmer/102E5%20Guide.pdf
Hope to be of assistance to you all,
Sincerly, alexander
Posted on Apr 29, 2008
Can I put my central heating on a different time from my water horstmann didam 425
It appears there are 4 trippers on the daily time dial that control all timing. 2 On and 2 OFF
On the right side are override switches for Hot water and Heating
You can only separate Hot water and Heater programming a little bit.
You can choose to have Hot water ON all day, or turn on-off once per day or turn on-off twice a day. Or OFF all day.
The Heater has the same options and the same on-off times as the Hot water.
Manual:
http://www.horstmann.co.uk/files/2513/9867/2118/user_guide_425-TiaraDiadem1.pdf
For fully separate programming, where Hot water and Heater can each be programmed differently, you would need a 2-channel controller like the Grasslin QE2
http://www.grasslin-controls.co.uk/towerchronqe2.html
http://waterheatertimer.org/pdf/Grasslin-QE1-QE2_GB-instructions.pdf
Gene
Oct 11, 2014 | Water Heaters
How do i set the heating/hot water timer on the LP112-24 acl controler ?
The instructions are available here: http://www.draytoncontrols.co.uk/Complete_LP_Installation_User_Instructions.aspx I hope I have been of help but please do not hesitate to ask if you have any further questions. Set the central heating Press the YES button, and the display will ask 'SET CH PROG?'. Press YES and you'll see ON1, the start of your first central heating period. Adjust it in 1-minute steps using the - and + buttons. If the - and + buttons are held down, the time changes in 10-minute steps. Press SET?, and you'll see OFF1, the end of your first central heating period. Adjust this in the same way, press SET?, then repeat the procedure for ON2, OFF2, ON3 and OFF3. Set the hot water When you press SET? after setting OFF3 for the central heating, the display will ask 'SET HW PROG?'. Press YES, then set your times in the same way. Remember, in this mode you can have different times to your central heating if you wish. When you press SET? after setting OFF3 for the hot water, the programmer will return to normal operation.
Feb 19, 2011 | Heating & Cooling
Hey . i installed a thingy called smiley center frm google and now i cant get rid of it. please help!!!
Hi, Please follow the below instructions inorder to uninstall the Smiley Central from your computer:- f you downloaded Smiley Central after March 11th:
1) From your computer's Start button, select "Settings", then select "Control Panel"
2) Double-click on the "Add/Remove Programs" icon
3) Select "My Web Search (Smiley Central)" or "My Total Search (Smiley Central)"
4) Click "Remove." Smiley Central and the toolbar have now been uninstalled.
If you downloaded Smiley Central prior to March 11th:
Depending on when you downloaded Smiley Central, you may be able to follow the steps above. If these do not work, please do the following:
Web-based email users:
To remove Smiley Central and your toolbar, you must do the following:
3) Select "My Web Search"**
(Click here to see a picture)
**Some toolbar versions may say "My Way Search" or "My Way Speedbar."
Outlook, Outlook Express and IncrediMail users:
To remove Smiley Central and the navigation bar from your email system, you must do the following:
3) Select "My Web Search (Outlook, Outlook Express, and IncrediMail)"**
4) Click "Remove." Smiley Central and the navigation bar have now been uninstalled from your email system. (Click here to see a picture)
**Some toolbar versions may say "My Web Search (Outlook, Outlook Express, and IncrediMail)" or "My Way Speedbar (Outlook, Outlook Express, and IncrediMail)."
To remove Smiley Central and the toolbar from both your email system AND your browser, you must do the following:
3) Select "My Web Search (Smiley Central)"**
4) Click "Remove." Smiley Central and the toolbar have now been uninstalled from your email system and your browser. (Click here to see a picture)
**Some toolbar versions may say "My Way Search (Smiley Central)" or "My Way Speedbar (Smiley Central)."
Incase you would like to disable Smiley Central from any particular application follow the below steps:-
Simply open Smiley Central and:
1) Click the "Preferences" button at the top of your Smiley Central window
2) Click the link under the "Enable/Disable" header
3) Check the box next to any application you wish to enable, uncheck the box to disable
4) Click "Save Changes"
Be sure to close any applications you have open, then open for your changes to take effect.
Thank you for your patience and best wishes for your effort.
Jan 08, 2011 | Facebook Social Network
My daughter has just moved house and inherited a Randall 702 time unit for her central heating but no manual was left. Where can she download one for free, please?
This programmer is very easy to use, I wish I could get a modern one so simple.
Use the 6 white buttons along the top to move the time setting bars to the desirded on/off times.
Then using the two rows of switches below decide if you want hot water or heating between the time bars.
Switch 1 is for operation between bars 1 & 2
Switch 2 is for operation between bars 2 & 3
etc
but Switch 6 is for operation between time 6 and time 1 the next day.
The slider switch has 3 positions
Off, Auto (ie the time settings above), and On all the time
Hope this helps but if you are scrapping the programmer please let me know
Dec 18, 2010 | Heating & Cooling
I need a Randall 972 Heating Programmer user manual. Please
For the answer to the original question relating to the Randall 972 Programmer see the comment and images I added to the original question.
Mar 30, 2010 | Hardware & Accessories
Danfoss TP5 programming manual required
This is the full manual:
http://danfoss-randall.co.uk/PCMPDF/6218.pdf
Very well hidden away on the Danfoss website!
Oct 29, 2009 | Honeywell Electronic Programmable...
Siemens central heating control
I have a Siemens "Radio" Room Stat - the receiver has switched itself off. How do I restart it. I have pressed the restart button and the reset - nothing happens except for red light flashing and then off. I do not have the instructions. Where might I get them?
J W-K
Oct 18, 2008 | Water Heaters
Heating & Cooling Logo
1,595 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
