Question about Frigidaire FRS23H7C Side by Side Refrigerator
Frigidaire side by side
Seems that there isn't a good seal on the fridge side,and theres codensation on the inside(this is a outdoor unit).....any solutions?
  • 828 Answers
Refrigerators and designed to be operated in the same conditions that we live in. Outdoors if the ambient temperature is low at night it will not run long enough to dehumidify the refrigerator compartment.
It may not be your door seal that is the problem, only the location and conditions under which you are operating it.
Posted on Apr 29, 2008
Frigidaire model #plrs267zab8 food in the freezer seems to be defrosting and appliance seems to be constantly running
check seal on freezer door for cracks or splits-replace if needed-check to see if water is going to pan at the bottom of fridge-hose may be plugged-clear blockage-is there water in fridge? remove goods from freezer-remove cover at back-may be frozen on element-defrost-if none of this works it can get more complicated and costly-may need a pro-if old replace.
Jan 28, 2017 | Frigidaire Refrigerators
RS265LABP freezer works but fridge doesn't.
if the evap fan motor isn't running then most likely this is you rproblem
Nov 25, 2011 | Samsung RS265LABP Side by Side...
I have an Gallery series Fridgidaire side by side fridge, model number GLHS68EJSB0... the line to the water filter keeps freezing and unable to depense water... we have the setting on the fridge set to the...
We have the exact same problem. But ours is in a vacation home so we have to keep the water turned off all the time. It seems something in the ice line freezes when the fridge is empty. Then, no ice, no water. When we turn the water back on, after a few days of having food in the fridge, it seems to make everything melt and flood the tray then leak out onto the floor all day and night. The fridge temp goes down to 12 degrees when the fridge side is empty. It seems to stabilize when there are items inside. We put several gallons of water inside instead of leaving it empty and it helps with the temp but not with the leaking. We have had service come out several times and they just said, "don't leave it empty and turn off the water when you leave." What good is that? I don't have water or ice for the weekend when I go up to the house! OR I clean up floods the entire time!! Now it's out of warranty. Now that I see it happens to people in their main house, I would just say NEVER EVER EVER BUY FRIGIDAIRE AGAIN!
Sep 24, 2011 | Frigidaire FRS3R5EMB Side by Side...
There's ice builds up inside the air circulation vent from the fridge side. This make less air coming from the freezer to the fridge, and the fridge is not getting cold, sometimes there isn't any...
you may have a seal problem on your doors make sure all seals seat to the fridge body properly, I suspect moist air getting in the fridge or someone putting hot food in it after supper :-)
Jul 05, 2011 | Kenmore 44273 Side by Side Refrigerator
Fridge side of side by side Frigidaire not working
your damper door is frozen or iced up and not opening up to let cold air in from freezer compartment,defrost it and make sure its dry,also check your door seal to make sure its sealing good and not letting in warm air that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
Flashing #4 on temperature display
flashing #4 is a communication error between the control board and the damper assy, usually it is the fault ogf the damper assy but if it is under mfg warranty, replace both, if you need to pay for the parts yourself get the damper first.
Oct 24, 2009 | Frigidaire GLHS36EESB Side by Side...
Whirlpool Defrost pan overflow
check and see if the door to the ice chute is closing all the way, moisture can get in there and cause excessive frost build up also check the location of your defrost thermostat behind the back panel in the freezer, it should be attached to the top of the evap coil. also check your water system and be sure that there are no leaks under the refer dripping into the pan while the unit is cycling for ice fill or dispenser line.
Sep 19, 2009 | Frigidaire FSC23F7D Side by Side...
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Freezer door opens
its air pressure between the wo doors that cause it to open the freezer door.take some soapy water and clean the sels aroundboth doors to see itf thet dosent help use dish soap and a little water to clean the seals with it should stop it
Jan 07, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS23H7C Side by Side Refrigerator Logo
50 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
