Power cord sanyo vizion model clt2054 dc in 12 volt power cord
  • 2 more comments
  • Tajiiquick Oct 24, 2008
    I need another power cord model is CLT2054. My television is unable to work with out it. I have been unable to watch mt tv for months!
  • myers-randy Nov 09, 2008
    I need a power cord for the Sanyo CLT2054.
  • Anonymous Mar 27, 2009
    I've been without TV for a while too ... i moved and can't find my power cord .... went to part search on Best Buy ... they no longer carry it .... what can i do?
  • dasta21 Apr 04, 2009
    i need power cord for clt2054 sanyo
DON DE PUEDO COMPRAR UN ELIMINADOR DE 24 VOLT
Posted on Aug 25, 2008
I need vizion cl t2054 tv power cord
I believe you may have an old laptop adapter which the same power cord works on your TV too..
if not you can
Try websites like Amazon.com, or Ebay.com to buy the a/c power cord.
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Aug 01, 2011 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
My Sanyo TV just quit working one day after a bad electical storm Its a Model number CLT2054 with an external 12 volt AC to DC converter cord. I thought it may be the converter and replaced it via the...
Did you bought your replacement AC Adapter on Ebay. well I bought mine on Ebay as well but you know what they're not the exact replacement. I encountered a problem with mine, because of the reverse polarity on the output power. you can fix this though, cut the output wire leading to your TV then connect the white wire with the un-shielded one and to the same on the other wire.
Sep 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Sanyo CLT2054 - power cord has light but when I plug it into the
OK you need a volt meter to check the voltage output of your power pack as two things cause this now enough power out the pack to run your unit or the unit has a short both problems will unlight the light so you need to know if the power supply is working right first as it should say like 120 volts AC in and 12 volts DC 1000 ma out so you will need to mesure this with a volt meter. this is a common problem loading the load of the curcuit as in your TV is mor the the power pack is giving out thus shorting out the power pack of any voltage present, as the little LED light your seeing only takes 5 volts at very ittle current to light and dose not repersent the total voltage output of the power pack itself
May 16, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Apr 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Screen went black
Check the power supply for 12 volts dc, it must provide at minimum 3 amps of power to trigger the on circuit. If not, replace the adapter... if you need one, please contact me.
Jan 12, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Power Cord
Please let me know when I can get the power cord & AC adapter. I moved and lost them and cannot use my television. Thank you R. Werkheiser
Nov 03, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
12 volts plug in for my TV
Sure. These are called power inverters. Here's a link to one that should work. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=422932&CatId=237 Make sure you look at the wattage rating of the electronics you wish to run on the inverter and make sure you don't exceed that wattage rating on the inverter. You can get larger inverters but they have to be usually hardwired into the battery system of your vehicle.
Jun 23, 2007 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Televison & Video Logo
692 people viewed this question
Top Televison & Video Experts
Electro Med Services...
