I bought a converter box for our analog tv and I programmed it to turn the tv on and off but I cannot nget it to change channels. I also programmed it to raise and lower the volume .
    Genius:
  • 1,142 Answers
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Posted on Apr 29, 2008
Tv as of sun night says no signal....converter box was working
Re scan your channels. Analog is gone and alot of channels have moved. Just re-run the setup on your converter and it should be fine. The channel numbers may change, but the programming hasn't. Hope this helps
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Insignia tv, universal remote, and.....
Follows steps below to program your Insignia Converter Box:
1. Turn on your TV using your TV remote control and change its channel to 3 or 4.
2. Turn on the convert box; the blue light on the converter box is on. If you press the power button again, the red light on the converter box will be on, but do Not turn it to Red!!! Your insignia's other buttons will not response if it in red light mode!!!
3. Then press the Menu button on the Insignia remote control. A wizard will appear. The wizard does not appear if your TV is not in channel 3 or 4.
4. Follow the wizard instructions to scan channels.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
Can I watch tv on 1 channel while recording another?
Unfortunately no, unless you get a second converter box. You're using the converter box to select channels, and it can only be on one channel at a time. With a second converter box, you might find you need a second antenna too (so you can get a signal on both channels). And you can't program your VCR to record on different channels (since it can't control the coverter box to change channels).
(This is a case of history repeating itself. When cable TV was new, and most TV's and VCR's weren't cable-ready, you needed to use the cable company's converter box. The same problems came up then too!)
Nov 30, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital to analog converter menu doesn't come up
When my Menu did not come up, I found it on the AUX channel (one below channel 3). I was able to go through the set up, but found only one digital channel available. Hope this helps!
Nov 10, 2008 | Televison & Video
Analog Pass-Through DTV Converter Box with Remote Control (3 digit code for the Remote Control
i can not get my tv to pick up a signal.I know my antena works i have tried it on other tvs.Has anyone else had this problem or know how to fix it?
Aug 04, 2008 | Philips Magnavox 20MT133S 20" TV
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Taping to a VCR post converter hook-up
cant you just turn the channel on your DCB and then record on the vcr?
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
