Question about HP Pavilion A610n (PC106A#ABA) PC Desktop
Hp a610n it is set at 115v
I need a vga driver for xp for hp pavilian a610 & also sound & other drivers
Posted on May 22, 2008
  • samara779 May 22, 2008
    need all xp drivers for hp pavilian a610
    Sergeant:
    Champion:
  • 329 Answers
You need a transformer to convert your voltage to 220v
Posted on May 14, 2008
How to test the electrical system of the generator for free
Ez test to determine if stator wiring is ok. This test works on generators that have two sets of 115v plugs and 220v plug. Use a 12v, 1amp ac power supply ( smaller ac power supply should work ok ). With generator not running, apply 12v to one of the 115v outlet plugs. Now verify 12v output voltage with meter at another 115v outlet on generator. Also verify that there is about twice the voltage at the 220 v outlet plug (should be about 20v - 24v) . If the adjoining 115 v outlet plug has no output or very little voltage or if the 220 volt plug has no output, most likely stator is damaged or breaker is off. If the stator is shorted voltage reading will be very low and power supply will heat up. If stator is open, there will be no voltage at second 115v plug or 220 v plug. If voltage is ok at the other outlet plugs as per test above then most likely problem is with voltage regulator, or brushes not making contact or armature winding open or just needs to be energized. Unplug the 12v power supply after test to prevent it from overheating. Most generators have two 115v windings that together power the 220v plug. When you energize one of the windings with the 12v power supply, the second 115v winding will be energized also and give you a voltage reading about equal to 12v. You will not damage the generator with this small voltage being input thru the plug. Good luck
Oct 14, 2014 | Electrical Supplies
My computer will not come on , it is plugged the screem is in power save , it sound like it's dead, I have no solution can you help
Check the power supply first to make sure it hasn't gone bad. Note: I had a case where somebody changed the input voltage from 115V to 230V. It did not work on a 120 Volt outlet until I discovered the red slide switch on the back of the power supply was in the wrong position. Maybe somebody thought it was an on/off switch. It isn't often that people get off so easily, but it's worth a look.
(The voltage setting switch is next to the power cord socket, is generally recessed slightly so it's hard to mess with it. Usually it's colored red, but is sometimes black, and is always marked 115V in the correct position for U. S. operation. If it reads 230V that is the problem, unless you are outside North America and using 230 Volt power. In that situation setting it to 115V may cause major damage.)
Nov 04, 2010 | Computers & Internet
I just bought a AOSmith 1hp pool pump. I do not
Well first did you have an old one you're replacing? Check it. Second you could test your voltage with a tester (best idea then you know for sure). Third, you can look at the circuit breaker in your panel, and if it is a single breaker , it is 125V If it's a double pole breaker (two wide with wide handle) then it's 230V. Usually if it is 230V then the wires coming to it would both be black, or black and red, with a bare or green ground. Usually if it's 115V you'll have one black (hot), one white (neutral) and one bare or green(ground) but at times someone will wire one 230 with black and white. There should also be a large bonding copper jumper connected to a lug on the outside of the motor to bond your system to the pool (NOT AN EQUIPMENT GROUND)
Jul 05, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
The pump comes factory set for 230v. Power to the motor is 115v so I switched the jumper as indicated. The jumper is set on 2 posts with an arrow pointing to 230v. I moved it to 1 post and the arrow now...
CHECK YOUR BREAKER IT MIGHT BE THAT YOU ARE 230V .. IF IT IS A WIDE BREAKER ITS 230 OR IF IT IS A SLIM BREAKER ITS 115V , A VOLT METER IS YOUR BEST FRIEND.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 29, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
Ok i neeed help!!!!!!!! on my power supply there is a switch which you can move to 115 volts to 230 volts. everytime i switch it to 230 volts the computer wont turn on? why is this happening? when i put it...
This is the power supply for your PC, depend on your local country power supply, some country like North US may use 110 V in their daily use electrical stuff and some country like Euro, UK use 240 V.
Your PC power supply is design to suit this 2 type of power input so can be sold everywhere. What u need to do is to make sure your local country power supply voltage and then just switch the input correctly, i think u have done it.
YBC (/\)
Oct 20, 2009 | Computers & Internet
Switching my hayward pool pump from 230v to 115v. I was told i could just move the jumper, line up the arrows for 115 and be fine but my gfi keeps tripping out?
Setting the pump for 115V wont by itself cause the trip. There is either a ground in the circuit or the GFI is bad. You may want an electrician to test any further than this.
Jul 03, 2009 | Hayward 3/4hp Super Pump Inground Pool...
My motor is wired for 230v and I need it to be 115v
It should be. Look closely at the motor nameplate and you should see a small diagram telling how to connect the motor for 115v or 230v. Most newer pumps have a small selector of some sorts. Either a plug that pulls off a couple post the include an idicator arrow for where to set the plug for either voltage, or a dial you turn to show it. Either way, you should be able to set the motor for 115 rather easily.
Jun 14, 2009 | Pentair Whisperflo 3/4 Hp 115/230v
10,000 watt generator 220 plug doesn't work
Most generators have several circuits incorporated within the windings. There are usually two 115v windings, one or two windings that produce power and sensing voltage for the regulator that supplies power to the armature (produces magnetic force) and sometimes a 12v winding to supply power to charge the battery. The two 115v windings power one 115v plug each and together power the 220v plug. Each outlet has a breaker and or ground fault. Since the 115v plugs are working indicates that the 220v plug must have an open/broken wire or faulty breaker. Easy to check, however you must open cover to wiring compartment and trace wires. Should be easy fix. You do not have to start engine to find broken wire. Use ohm meter instead. With engine off, Insert probes into 115v plug and obtain ohm reading. Then insert probes into second 115v plug and obtain similar reading. Look for same reading at the 220v plug (remember 2 circuits of 115v, ground and neutral). Good luck with your repair and email if you have other question.
May 09, 2009 | Electrical Supplies
Inverter problem
If you got the store bought APC 350 UPS, you most likely overloaded them, and killed them beyound repair.
People should never buy a 350VA. They are way to small for power supplies most of us now have. you need to start out to 1000VA plus you need to do the math to figure out how big of a UPS you actually need in the show room.
What am I talking about? What is the significant, or the math of what I am saying here. 115V x 1 amps = 115VA x .778 power factor = 89.47 watts Start up 50 watts = 39.47 watts
115V x 2 amps = 230VA x .778 power factor = 178.94 watts Start up 50 watts = 128.94 watts
115V x 3 amps = 345VA x .778 power factor = 268.41 watts Start up 50 watts = 218.41 watts
115V x 4 amps = 460VA x .778 power factor = 357.88 watts Start up 50 watts = 307.88 watts
115V x 5 amps = 575VA x .778 power factor = 447.35 watts Start up 50 watts = 397.35 watts
115V x 6 amps = 690VA x .778 power factor = 536.82 watts Start up 50 watts = 486.82 watts
115V x 7 amps = 805VA x .778 power factor = 626.29 watts Start up 50 watts = 576.29 watts
115V x 8 amps = 920VA x .778 power factor = 717.76 watts Start up 50 watts = 667.76 watts
115V x 9 amps = 1035VA x .778 power factor = 805.23 watts Start up 50 watts = 755.23 watts
115V x 10 amps = 1150VA x .778 power factor = 894.70 watts Start up 50 watts = 844.70 watts
115V x 11 amps = 1265VA x .778 power factor = 984.17 watts Start up 50 watts = 934.17 watts
115V x 12 amps = 1380VA x .778 power factor = 1073.63 watts Start up 50 watts = 1023.63 watts
115V x 13 amps = 1495VA x .778 power factor = 1163.11 watts Start up 50 watts = 1113.11 watts
115V x 14 amps = 1610VA x .778 power factor = 1252.58 watts Start up 50 watts = 1202.58 watts
115V x 15 amps = 1725VA x .778 power factor = 1342.05 watts Start up 50 watts = 1292.05 watts
115V x 16 amps = 1840VA x .778 power factor = 1431.52 watts Start up 50 watts = 1387.52 watts
115V x 17 amps = 1955VA x .778 power factor = 1520.99 watts Start up 50 watts = 1470.99 watts
115V x 18 amps = 2070VA x .778 power factor = 1610.46 watts Start up 50 watts = 1560.46 watts
115V x 19 amps = 2185VA x .778 power factor = 1699.93 watts Start up 50 watts = 1649.93 watts
115V x 20 amps = 2300VA x .778 power factor = 1789.40 watts Start up 50 watts = 1739.40 watts
Sep 16, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
HP Pavilion A610n (PC106A#ABA) PC Desktop Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
