Question about Apex Digital AT3208S 32" TV
Apex TV Do Apex Tv's have fuses in them? My sister has a tv and it is not turning on TV had no picture , I noticed a fuse was blown, but have no luck on finding one. Do you know where I can get it?
  • 1 more comment
  • barbb372 May 13, 2008
    I HAVE THE SAME PROBLEM I HAD MY TV FOR LESS THAN 1 YEAR , AND ONE DAY I WENT TO TURN IT ON AND NOTHING HAPPENED NOTHING, AND I CAN NOT FIND ANY ONE TO FIX IT , THEY SAY IT IS TO NEW ,NO ONE HAS PART'S, IF ANY ONE CAN HELP ME THAT WOULD BE WONDERFULL,
    YA'ALL HAVE A BLESSED DAY!
    greeneyedlady501@aol.com
  • Anonymous Sep 22, 2008
    tv wont turn on
  • ekimynot Nov 02, 2008
    Same problem. Turn on the TV and nothing happens. I think it is a .5 amp fuse.
It may be a little late for your answer, but it takes a 5A 125V fuse commonly found in christmas lighting...Ace Hardware has them for a bout $1.50 for two....
the problem is this, something caused your fuse to blow...so if yours is like mine, you'll blow a fuse everytime you put one in because there's a short in the circuitry...which means either get a degree in electrical engineering, or buy a new tv.
Posted on Sep 14, 2008
My sister was messing around with my T.V. on the menu and did something and now it wont turn on
First things to do : please check your power supply for malfunction and TV fuse for blown.
Jan 17, 2011 | RCA TruFlat 27F520T 27" TV
Apex tv
should be inside the back cover on the left hand side toward the rear of the television
Feb 18, 2009 | Apex Digital AT3208S 32" TV
Blown fuse inside tv
Look at the fuse you pulled out. The rating is embossed on the side or end.
Dec 28, 2008 | Apex Digital AT2008 20" TV
Blown fuse on panasonic tv
Maybe the horizontal output IC are on short circuit.
Nov 04, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Sound problem
It is really unusual that you retained the picture part after the lightning strike, but what is wrong now is in the audio portion of your tv (obvious). However, if you have not taken the back cover off already it could be as simple as a blown fuse in the low voltage power supply or just blown audio amplifiers due to the sudden voltage and current surge caused by the lightning. The fact that you can get your audio through your surround system kinda narrows it down to the audio amplifier section. Just take the back off and look because those size tvs do not have alot of boards. All in all see if the problem is visually obvious like a fuse, because with out taking actual voltage measurements it could be a couple of boards in there causing the problem. Good luck and let me know. God bless you. Robert
Aug 27, 2008 | Apex Digital AVL2776 27 in. HD-Ready LCD...
Have dec tv cannot get picture or sound will not auto tune
You mean to say is "dead set' .This kind of trouble is in power supply section busted fuse or busted regulator transistor ,or maybe no depected parts only brittle,loose,crack or cold solder joint of the circuit board...
Jul 22, 2008 | Televison & Video
Power surge I think
If you do not get any clicking or sound when trying to turn on the TV set, most likely the main fuse went out. This is almost always due to something else blowing out along or making the fuse to blow out. DO NOT SIMPLY REPLCE THE BLOWN FUSE! If there is other shorts inside the set, and you replace the blown fuse, you can cause more damage to the TV set. The best way to test this set if the fuse is blown would be to hook up a 100 to 150 watt light bulb across the blown fuse, and if there is a short in the TV set the light bulb will glow bright and stay bright. If the bulb lights up and goes dim maybe just maybe you got luck so replace the fuse and see what happens. If the light bulkb stays bright, there is a short in the set somewhere and if you do not have a service manual and a good multimeter and a knowledge of how the TV power supply works, you really should call in a pro to assist you in the repair of this TV. there is just too much High Voltage inside these TV sets to be experieenting around inside of it. Good Luck.
Mar 14, 2007 | Toshiba 36A43 36" TV
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Picture, but No Sound
I doubt if it has fuses as most sets have what are called fusable resistors and these as fuse hardly ever go bad for no reason. these devices are there to protect the rest of the set incase of a short and to stop it from blowing up or burning. Fuses or fuseable resistor go our because of a short circuit. In your case the sound output IC or the capacitor assciated With it. Good luck
May 28, 2006 | Apex Digital AT2702 27" TV
Apex Digital AT3208S 32" TV Logo
243 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
