Question about Sony Cyber-shot DSC-W50 Digital Camera
Flash - Why won't it turn on?
I have the sony cybershot W35/W55 and the flash will not turn on. As i press the flash button, it beeps three times and the "flash forced off" symbol shows up. I have no idea how to turn it on, so could someone please help me? : )
  • Anonymous May 05, 2008
    i didnt drop it or anything. my camera just does turn on
  • 797 Answers
Do some of the following things.
Reset the internal menu settings, then reset all the options you want your way.
Make sure the flash is on in the picture taking option you choose.
When you have enough light, the flash usually will not go on, and if it is on the amount of light can force the flash off...'
Here is a link. http://www.dummies.com/WileyCDA/DummiesArticle/id-869,subcat-ARTS.html?print=true
Posted on Aug 04, 2008
My Sony Steady Shot DSC-S950 won't flash. I have pressed the flash setting several times as suggested in blogs to no avail.
Sep 15, 2011 | Sony Cybershot DSC-S950 Digital Camera
Sony Cybershot DSC-W55 Flash Error Code
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Mar 24, 2008 | Cameras
Hello i have a sony dsc-w35/w55 camera and when i switch it on i get access then it bleps and says turn off power and on again but still cannot get to operate .Can it be fixed?
Due to malfunctioning of FLASH UNIT assembly this message appears"turn off the power and on again". A very common problem in these models. Just replace the COMPLETE FLASH ASSY and camera will work fine again. The detail of part is given below:
1- For DSC-W55 Part Number Description
A-1231-877-A ST-133 BOARD, COMPLETE
2- For DSC-W35
A-1254-671-A ST-133 BOARD, COMPLETE
Thanks.
May 13, 2011 | Sony Cameras
I have a sony cybershot dsc w55 with error e:91:01. i have pressed the reset button and initialised the camera numerous times. the error is removed but the camera will not take a picture in auto or p mode...
E:91:01 is an error code that indicates problem with flash unit circuit in camera.
Flash unit board will be replaced to resolve this problem and temporary fix is to set flash Off quickly, before error could appear after initializing camera, hope this info will help you.
Thanks.
Oct 18, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
Sony Cybershot DSC-W55 flash not working Code
GO TO SETUP MENU, SELECT THE TOOLBOX ICON 1 AND SELECT INITIALIZE CLICK OK.
Aug 10, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Flash overexposing
  • Page 22 talks about adjusting the flash level see the instruction manual - link below
  • Looking at the handbook - see other link below - Page 41, details how to adjust the flash level, for more or less output
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 07, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Problem when starting up sony cybershot W55.
Your problem is mainly like above.
If you want to check the other troubleshootings please download the user manual of Sony Cyber-Shot DSC-W55
Feb 22, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My flash on my sony cybershot will not turn on. the button doesnt want to work it just beeps, but everything else works fine. Can I fix this?
Set camera on auto (green mark) and turn on flash by pressing flash sign button.
Or initialize camera by going into menu.
Aug 27, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Error Message E91:01
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Oct 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cybershot w55 flash speed and recording folder
One flash is for the camera the set the exposure the second is to miminize red-eye the third is the actual flash. All digital cameras do it, you can only turn off the red-eye flash.
Jul 10, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
100 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
