My whirlpool washer washes on the hot cycle but does not funcion on the cold rinse cycle
  • Anonymous Mar 14, 2014
    Washer doesn't work on cold cycle
    President:
  • Washing Mach... Master
  • 2,651 Answers
Check your incoming water supply, if your water into the machine is good, sounds like a bad inlet water vavle
Posted on Apr 29, 2008
I load washer it starts the wash cycle it goes through wash cycle fine drains water but does not collect water for rinse cycle it just idles. So I turn knob to spin and it spins until done.
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Sep 17, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
Water will come in at beginning of cycle on a Hot/Cold wash but not in rinse cycle?
because the rinse uses cold water and u may have a cold water issue with the water inlet valve, the water inlet valve cold coil may have gone bad. test it with a meter and voltage
May 11, 2015 | Whirlpool GHW9400 Duet Washer
I have a wtw5800swo washer. The washer will complete the wash cycle, but then shuts off and will not enter the rinse cycle.
Be sure to guarantee that BOTH hot and cold taps are turned on. Commonly, the hoses get reversed, and dad turns off the hot water (due to high bills) and the hot is connected to the cold tap, which is used for rinse, so the machine will wait forever for the water...
Apr 07, 2011 | Whirlpool WTW5850S Top Load Washer
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool washer new..,. washes cold wash cold rinse.. hot wash cold rinse.. but on warm wash is cold wash cold rinse I can send wasdher back just got it t0 day or is there something I can do?
Be sure the hot water valve is all the way opened first. Both faucets must have equal pressure for washer to work properly. They all rinse with cold water, this is normal.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
Whirlpool washer problem
it sounds like you cold inlet need replaced its a easy job
Jan 10, 2008 | Whirlpool AWM6100 Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
