Question about Samsung DVD-R130 DVD Recorder
Disc tray frozen in closed position
Froze while i was watching a program. Said then and still does "SAFE". and that's all. Can't work it from remote or manually - and, of course the disc is still inside machine. Please advise. Thanks.
    Genius:
  • 1,226 Answers
Unplug the it to the wall outlet, refer to your manual for the emergency disc remover.
After removing plug in to the wall and then try new disc, may this is damage.
may this help,
melnavz
Posted on Apr 29, 2008
  • 758 Answers
It sounds like a mechanical problem with your CD-ROM. Most of these devices can sense when a slight pressure is put on an open tray, which causes the tray to close. This is not the preferred method of closing the tray, but a design feature to retract if the tray is pushed instead of the button on the drive.
It seems that your drive is experiencing pressure when the tray is opened, causing it to malfunction. It could also be that the "bouncing" you mentioned is causing it to rebound into the auto retraction area. Either way, it is a mechanical malfunction and you should return it if it is still under warranty.
Hope that helps
Thank you
Computerrep
    Genius:
  • 3,587 Answers
Ok..turn it off..unplug it..then restart with power on and see if it automatically recycles the disk
    Guru:
  • 1,342 Answers
Unplug it for a few minutes to reset it and then plug it back in again.
  • Georgia B
    Georgia B Apr 29, 2008
    The manual says to turn it off press and hold the power button for 10 seconds. After it shuts off press the Open button to remove the disk.
How to change toshiba sd-412v region 1 to free region?thanks
Hi friend. Try this:
Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. Remove any disc that might be on the tray before proceeding.
Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
Press the "9" key on the remote.
Press the "Open/Close" button to close the disc tray. Press the power button to turn the Toshiba DVD player on.
Hope it works.
Jun 16, 2011 | Toshiba Televison & Video
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
Unknown disk type
Press 'Disc Menu' and wait for 'no disc' to appear on the screen. Eject the tray by pressing the 'open / close' button on front of the recorder. Enter the following numbers very slowly on the remote control ' 0086000 ' Press ' OK ' button on your remote control. Close the tray by pressing ' open / close ' button on the front of the recorder. You can check this has worked by pressing ' 0009 OK ' on your remote after the tray has closed. A display will pop up on screen showing the Region as 0. This means you should be able to play discs from all Regions. If this doesn't work the first time! try again! Hope this helps!!
Jan 24, 2009 | Philips DVDR3380/05 DVD Recorder
My Samsung BD-P1400 is frozen on "load" and disc tray won't open
My player worked fine couple of days ago, then last night when powered up, message was "load" and it stayed like this forever, and tray open would not work. Tried everything, nothing worked. Left unplugged from power for 24 hrs and bingo everything worked as should. I suspect that the unit is still trying to load info from last disc which I stopped in the middle of some bonus material, even though the disc was no longer in the tray.
Dec 26, 2008 | Samsung BD-P1400 Blu-Ray Player
I need to change region code for goodmans GDVD200CDGM
Region Code Hack: GOODMANS GDVD-200-CDG:
To convert this player to Multi-Region
1. Open the disc tray.
2. Place a region 1 disc in the tray, but don't close it.
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
4. Press the play button on either your remote or the player.
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control.
3. Press the Retu To return this player to Region 2 only (alternative method) rn button on your remote control.
4. Your player should now go into Standby mode.
5. Press the Power button on your remote control.
i). Open the disc tray
ii). Place a region 2 disc in the tray, but don't close it
iii). Press the buttons Return and then Play on your remote control in order, one at a time
Aug 21, 2008 | Goodmans Televison & Video
Need code for durabrand portable dvd player
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
How do you put on a dvd?!
i take it all set up the dvd to tv.?
turn on the dvd player with the remote .
press open on the remote
insert the disc dvd out of the box
close tray
press play to watch dvd
when finished
press open take out disc and close disc tray and turn off dvd player .
riz.
May 24, 2008 | ASUS DRW-1608P2S DVD RW Dual Layer Burner
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Jvc xv-thc3 tray is frozen
The changer mechanism needs to be manually reset. Maybe due to a broken gear.
Oct 28, 2007 | Audio Players & Recorders
Samsung DVD-R130 DVD Recorder Logo
244 people viewed this question
Henry  Thomas
Henry Thomas
