TV power loss
Panasonic LCD TV #TC-32LE60 popped and turned itself off. When attempting to turn back on, power light flashed 6 times and paused, flashed 6 times and paused, repeatedly. Unplugged for 20-30 sec then restarted, getting a set-up menu. Canceled menu and it ran for about 2 min but popped again. Left unplugged overnight and it now seems normal. What does the 6 flash code mean?
  • 3 more comments
  • Candalino Apr 29, 2008
    This did not really help as I already figured some thingy inside the TV might be bad. My question is "what does the power light six flash code mean?? As I said, the TV is now operating normally after being unplugged overnight.
  • Candalino May 01, 2008
    The first thing I did was check the operating manual. It says nothing about the power light flash codes and I didn't really expect it to. For the paid FixYa assistance, I expected that someone with some technical experience would be able to find that info. FixYa has taken my $10 and provided nothing. I will not be back and will recommend against it unless I can get that information.
  • Candalino May 02, 2008
    Panasonic LCD TV #TC-32LE60 popped and turned itself off. When attempting to turn back on, power light flashed 6 times and paused, flashed 6 times and paused, repeatedly. I unplugged it for 20-30 sec then restarted, getting a set-up menu. Canceled the menu and it ran for about 2 min but popped again. Left it unplugged overnight and it now seems normal. What does the 6 flash code mean? Maybe an overheat condition?? It didn't seem any warmer than normal... pcandalino
  • Candalino May 04, 2008
    Thanks, that's good to know. The TV is operating normally now though after being unplugged overnight. I am still curious to know what the six flash diagnostic code sequence on the power light means.
  • Anonymous Mar 31, 2014
    tried unplugging overnight then plugging back in the next day, sometimes will work other times not but always repeat the same problem over and over.
    Guru:
  • 147 Answers
I agree with Coolguy's answer. If that doesn't resolve your issue, the problem is the lamp. Getting that replaced at a local shop will cost around 150 dollars or more.
Please let me know if this helps. Take care!
-Chimpster
Posted on May 02, 2008
  • Alexander Kogl May 04, 2008
    didnt get rated tee hee ;) thanks anyhow coolguy
    Genius:
  • 3,422 Answers
Actually to tell what 6blinks mean it is not possible but this is the fix for it.disconnect the power cord for about 4 hours, then plug it back in;
  • Priya darshan May 02, 2008
    All i can say is 7 blinks means there is a component that is not operating properly.
    And please don't forget to rate or accept the solution no. 2
    Genius:
  • 1,142 Answers
Most likely the part inside the tv has gone bad as you said that you heard a pop and this lead to take the tv to a technician.
Posted on Apr 29, 2008
What can i do? Turned off TV. Now it will not turn back on. Flashes 10 times, pauses then starts flashing again
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 11, 2014 | Panasonic TC-P42U1 42 in. Plasma HDTV
Panasonic hdtv, TC-P42X1, no picture, no sound. Power light flashes 10 times, pauses and then repeats. TV will not come on.
Tries tv unplug,replug it back like about an hour later.The tv will be resetting itself back to the factory setting.Now the tv should be working again.If it still have the same problems.The tv have a power supply board problems.That the board,where the a/c power cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Jan 19, 2011 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Panasonic tc-p42x1 has no power and led flashes 10 times in between pauses is this tv worth fixing
No, it is definitely not worth repairing. The panel is shot and you can buy a new lcd tv for less than the repair.
Aug 10, 2010 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Where to get LCD screen for panasonic TC-32LE60 TV ?
Hi there, the only close part you could get is the actual cabinet. the actual screen will have to be shipped by the manufacture itself. these screens are filled with a liquid that is dangerous and has to be installed in a OSHA approved shop.
Feb 18, 2009 | Panasonic TC-32LE60 32 in. LCD Television
Dont have securtiy code to unlock tv
  1. Press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in.
  2.  Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
  3. Volume down on the unit and RH-Split on the remote-- same process
Try these one at a time until you find the right one.
Let me know if this helps and please rate this solution. Lone99star
Jan 18, 2009 | Panasonic TC-32LE60 32 in. LCD Television
Keeps turning off...
I've disconnected the power cord for about 2 hours, then plugged back in; and the problem was solved.
Mar 01, 2008 | Panasonic TC-32LX60 32 in. LCD Television
No power but has red light flashing
Thank God for the internet. I had the same problem and I googled it and found this site with this solution. It worked fine. Thank you. Like you said, unplug, hold the power button for 60 seconds and replug and turn on. Worked like a charm. Thanks a bunch.
Nov 13, 2007 | Panasonic TC-32LX60 32 in. LCD Television
Televison & Video Logo
157 people viewed this question
Top Televison & Video Experts
