F&P washing machine GW709NZ when push start "short wash" and "spin" LEDs are on and beeping, not working. Ran test cycle (progress indicators run back and forth, then all indicators on)
  • 3,037 Answers
Try holding the temp up button down at the same time as pressing the power button. Then press the temp up button for 5.5kg, water level up button for 6.5kg or spin speed up button for 7.5kg. Turn off power then you should be ready to go. Let me know if this still doesn't solve the problem.
Also, have you tried leaving it unplugged for 5 minutes.
Also, are all the lights on or which specific ones are on?
thanks
Posted on Apr 29, 2008
  • Benjamin Patri
    Benjamin Patri May 03, 2008
    Please don't forget to rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
    Genius:
  • 3,587 Answers
Is that F and P?
My F&P GW601 stops during final rinse, and beeps an error condition.
  • I just fixed a F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.)
    Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!!
Aug 29, 2015 | Fisher and Paykel Washing Machines
Washing Machine stopped through cycle and now will not turn on
Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Gw712 doesnt start just beeps
Lets see if an error code pulls up.
With the machine off, press and hold the Wash Temp Down button and then push the power button until the machine gives 2 short beeps and lights up. Now press the Spin Speed Up button three times so that the Hold and Slow LEDs are illuminated.
The eight wash progress LEDs will show the error code.
Apr 29, 2014 | Washing Machines
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
The low water level LED identifies 6kg.
If the product has not been setup before all 3 LEDs will be on.
the power button.
This locks the size
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
My fisher & paykel smart drive excellence 7.5 washing machine squirts water in a few times and then stops and beeps and displays 3 lights red orange and (short wash) green as well as low and med speed...
Although slightly unclear these are the only possible error combinations for the leds on the machine as you look at it with red always on the end right hand side.
(11) 1011 (Green - nil - Orange - Red) - pressure problems perhaps a blockage in the tube to bowl.
(13) 1101 (Green-Orange-nil-Red) - pump is faulty
(15) 1111 (all lights on) - display module is faulty
I do not recall that the leds across the spin speed actually means something.
Good luck
Jun 06, 2011 | Fisher and Paykel Washing Machines
Fisher & Paykel GW709NZ will not fill
Hi just read your posting.Your Error Code is 49.This means you have a Water Valve Fault.Would you like me to guide you throe the testing and repair of your machine?If you do then have you or can you borrow an electrical test meter to test the water valves?Please reply and tell me how you would like to proceed.Looking forward to your posting.
Jul 19, 2010 | Fisher and Paykel Washing Machines
We have a Fisher and Paykel toploader, smart drive 603. After setting up a washing cycle and pushing the start button, the machine starts for a few seconds with the water filling in in short bursts (rather...
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
Jul 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
Spin Led stays on and beeper beeps
this spin light that is on is a fault code no:1 which means the electronic motor control has a memory problem solution replace motor control module ... hope this helps..:0)
May 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
