Question about Dell Inspiron™ 600M PC Notebook
Battery not recognized
I have my laptop plugged in and "charging". The red battery light is flashing and when i open the power settings the battery doesn't even register. I also noticed a serious decline in performance once this started. I thought it was simply the battery died so i replaced with a new one with the same results. Please help.
  • wheelerx Apr 29, 2008
    aftermarket power cord and oem battery
  • Byron Wells May 11, 2010
    Is the battery a generic or OEM?
  • 56 Answers
Check the connectors where the battery slides in, if they are dirty, clean them with a q-tip and alcohol
Posted on Apr 30, 2008
    Scholar:
  • 144 Answers
Have you adapter checkup also that its supplying constant
supply.
Posted on Apr 29, 2008
Battery light flashing red
If you are using AC, remove battery. Charge battery and remove when plugged in for a period of time. It will last longer, the battery has a finite number of charge cycles.
May 17, 2013 | Acer EXTENSA 4630Z COMPATIBLE LAPTOP LCD...
My battery light flashes red then green then red and so on even though its plugged in. The power indicator says I'm fully charged. What doed the flashing red and geen mean?
Try removing the battery and just use the AC adapter. If the laptop functions normally then you have a problem with the battery charging circuit . Either your battery is defective or the circuit that charges it is defective ( meaning the system board).
Aug 02, 2011 | Dell Latitude D500 Notebook
My dell d600 is not charging what is the solution and it always flash red light when it is plug to power
That means either the battery is no longer good anymore or the laptop is unable to charge and/or recognize the battery. Try cleaning the contacts of both the battery and the laptop when everything is unplugged and powered off with alcohol and a q-tip. But usually if a laptop is not charging the battery then most likely you will need a new one
Apr 13, 2011 | Dell Latitude D600 Notebook
I have a DELL Inspiron Mini. The power LED light is alternately flashing white and red. The netbook will not come on unless I have the power cord plugged in. When I do plug it in and power on, the...
This could indicate a bad battery. Try removing the battery and powering on the laptop. If the power LED remains white then you have a problem with the charging circuit. That means your battery could be defective or the battery charging circuit on your motherboard is faulty.
Feb 21, 2011 | Dell Inspiron Mini 10 Notebook
Red battery light flashes when chargin dell latitude
If the battery light flashes red, this is usually an indicator of a bad cell in the battery or the battery is not being charged. This could be a power supply problem, a battery problem or a power adapter problem on the motherboard (The piece mounted to the motherboard that the power cord plugs into). Laptops are becoming notorious for this last problem.
Jan 06, 2010 | Dell Latitude D600 Notebook
Hi, The battery light on my Inspiron 6000 flashes 3 times red and then green repeatedly. What does this mean? Also, after the computer is plugged into an outlet for an extended period of time the power...
the battery has reached its expected life, you need to replace it. If it is under warranty, you can call dell and have them replace it. You can still use you laptop with the wall power/charger plugged in, remove the battery to get rid of the flashing red/green light.
Jul 10, 2009 | Dell Inspiron 6000 Notebook
Bought a Dell Inspiron E1505 Laptop
I have a e1705 dell and mine I had to replace the power cord .The battery was not charging.
Jun 26, 2009 | Computers & Internet
Laptop won't power up
when u get power on of your laptop .u seen Red/orange light blink 4 times on front panel.it means your laptop battery is not getting charge.please get charge for minimum 6to 8 hrs & then try to on .if y u laptop battery is get charge u r laptop will started on (also confirm your A/c adapter is working .green light is display on front panel it indicates charging on )
Jul 09, 2008 | Gateway MX6124 Notebook
Dell 600m Laptop Killing batteries
If you are using known good batteries, and you have the most current BIOS Flash, then it is likely a failure of the charging curcuit on the motherboard. The flashing Amber (Some people see it as red) led indicates a failed battery
The Multiple good batteries, I assume have been recently purchased, because computer batteries are consumable and are rated for 300 to 500 charging cycles before they wear out.
I replaced my 700m motherboard with one from Ebay for about $170.00 about a year ago.
Jul 05, 2008 | Dell Inspiron 600M Notebook
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Dell Inspiron™ 600M PC Notebook Logo
54 people viewed this question
Alun Cox
