Question about HP Compaq Presario V6171CL Laptop
Trouble With Internal Wireless Card/Wireless Assistant
My internal wireless card stoped working. I am also having problems with the pc recognizing the wireless assistant to run the wlan connection. what can I do to fix this
  • Stephen Perry Apr 29, 2008
    Under network connections there is only dial up and lan, somehow wlan link is not there
    Genius:
  • 3,587 Answers
Open up control panel, go to network connections first..see if it's enabled
Posted on Apr 29, 2008
  • Patrick Michaels
    Patrick Michaels Apr 29, 2008
    if it 's ok..uninstall it, and then re install it..
  • Patrick Michaels
    you can do second one from control panel, wireless setup icon
My Acer laptop wireless not working. It was
first network setup wizard then u try the internet through wireless
Nov 16, 2009 | Acer Aspire 5500 5570-2609 Laptop
My wireless wlan card wireless network controller stopped workg
TRY REINSTALLING THE WLAN DRIVER. OR CHECK THE INTERNAL ANTENA CABLES OF WLAN. IF IT NOT WORKS. THEN THE ONLY SOLUTION IS TO REPLACE IT WITH THE WLAN CARD.
DONT FORGET TO VOTE.
Oct 10, 2009 | Dell InspironTM 1501 Notebook
Wireless adapter not functioning-
Do the following :
  1. Turn Laptop off, then disconnect adapter and remove battery. Re assemble and restart.
  2. Try clicking the button activating the wireless card.
  3. Reinstall wireless card drivers, select drivers from Compaq Presario V6205NR Notebook PC
  4. If all that did not work, then the internal adapter is faulty. Buy an external wlan adapter:WLAN Adapter WL-167G-£12.90 new
Sep 26, 2009 | Compaq Presario Notebook
Wireless WLAN controller
Go to Control Panel, and find Network Connections. Find the wireless lan icon and RIGHT click on it. At the top of the menu that comes up, it might say "Enable". If it does, then something has disabled it, and you need to click on "Enable". If it says "Disable" then you probably have one of two problems.
1. Need to reinstall drivers (or update the ones you have)
2. Wireless lan is going bad, so you'll need to use a PCMCIA card to wireless.
Personally, I've never liked the built in wireless anyway. It's more of a sales gimmick than anything else.
Apr 28, 2009 | Dell Inspiron E1505 Notebook
Problem on startup with laptop combining internal ethernet and WLAN as if there is only one network connection I am trying to fix my mother's Acer Aspire 3680. It has 1GB of RAM, running XP Home SP3. It...
Sounds like the problem may be related to the power management of the internal ethernet card.
You need to check these settings in the Acer ePower Management software (usually installed with the laptop).
E.g. If you the laptop is not charging then you will not be able to see or change any settings on the internal ethernet card.
If you do not have the Acer ePower Manager installed then you can download it here;
http://acer-epower-management.software.informer.com/
Thanks
C
Apr 04, 2009 | Acer Aspire 3680 Laptop
Wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
Feb 03, 2009 | Dell Inspiron 1501 Notebook
Wireless network connection problem
Ok with a peripheral on USB or on PC card bay you can try to connect to a Wireless lan:
Please check this tip on the subject
To connect to an existing WLAN you must be sure your wireless card is working: I assume you installed all the related sw coming with the wlan card.
Using the card installed driver check card is enabled and running (in Control Panel/Network connection should be visible and enabled)
Then you can connect to an open Wi-Fi HOTSPOT or to your WLAN you configure with a router connected to your internet modem.
  1. To connect to an existing HOTSPOT: find a location where you know a wi-fi access point (HOTSPOT) is active: Internet cafe,, library, airport,, station, hotel etc.your card should be able to find the existing network when you select "show existing network" in wlan driver. Connect if network is "unsecure" (= no password or key is required) or ask for password if you can get it for a fee (hotel)
  2. To connect to your home or office WLAN be sure to use a router (or access point) with same standard of your card (802-11G or B or A or N) with same security protocol (WEP or WPA) and configure your router Internet access BEFORE wireless access. Connect your PC to your router using a LAN cable and be sure you can browse through the router.(contact your ISP for router specs if you need it: PPOA/E and other). Follow the tip and your router doc for settings
Jan 14, 2009 | HP Compaq Evo n610c Notebook
Internal wireless card has been disabled. How do you fix this?
Hi car7924,
First, make sure that the wireless switch on the left side of the computer is turned on (this should make the WIFI light go on -- beneath the lower right corner of the screen). If it doesn't work, then try going to Start Menu > Control Panel > Network and Internet Connections > Network Connections.
You should see the Wireless Network Adapter in the window that comes up. If you don't, you need to download the driver for that adapter. The most common adapter in the D820 is the Dell 1390 WLAN MiniCard, and the driver for it can be downloaded at the following web address:
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Dell-Latitude-D530-Wireless-1390-WLAN-MiniCard-Driver-A17.shtml
If, on the other hand, you do see the Wireless Network Adapter, but it says "Disabled" underneath the name, then right-click it and select "Enable." This should make it work.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 13, 2008 | Dell Latitude D820 Notebook
WLAN switch button does not work
Locate your wireless card compartment on your computer. It is probably on the back of it. Your computer manual should tell you where it is. Open the compartment and locate your wlan card. Remove it from your laptop for about 30 seconds, and then reinsert it and make sure that the proper connections to it are firm and secure. Close up the compartment. Turn on your laptop. Your laptop should search and recognize it. If it doesn't, then your wireless card probably quit working on you. If your computer is still under warranty, and if it doesn't recognize it after you have tried this, then you can contact your computer manufacturer and explain to them what happened. They should replace your wireless card at no charge. If you bought the wireless card from some other store, then take it to them and explain to them, and ask for a replacement wireless card.
Sep 04, 2008 | Averatec 3200 Notebook
Internal Wireless adapter failed
Your wireless zero configuration being manipulated by the add-on service of manufacturer software. first you can manually turn in the Wireless Zero Configuration by typing services.msc on run menu. After you run the services you will see Wireless Zero configuration please enable and start it with the given option.
Next you can open the Wireless Network Connection option, uncheck the add on protocols, such as AEGIS and WLAN protocol. after restart computer should work with wireless without problem.
Please post if you need further assistance.
Good Luck
Jul 21, 2008 | HP Pavilion dv1000 Notebook
HP Compaq Presario V6171CL Laptop Logo
200 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
