Question about Kenmore 62602 Electric Dryer
Timer doesn't shut down dryer machine
I have a commercial Kenmore dryer. Dryer keeps on running. Is there something wrong with the timer.
Junior
I have a 90 series Kenmore dryer. The dryer still works but the timer won't advance. I have to do it manually. It still heats ok but is a pain to have to remember to check on. Just wondering if the timer unit is reasonable to replace and if it is something that I can do myself? I would hate to have to sink a bunch of $$$ in it. Thanks.
  • FMoe May 16, 2008
    We have a Kenmore 70 series electric dryer and it just keeps running and has to be stopped manually.
The timer is easy to change, check how much it is first, mine was around $100.
Posted on May 02, 2008
We have a kenmore electric dryer that will not shut off.
model- 110.62722101
Posted on May 16, 2008
Will not power off
How To Fix Dryer That Won't Shut Off ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Shut-Off/
The toughest part is figuring out what dryer part is the problem. We've created a list of the most common parts that can cause a dryer to not shut off. Use this list to ...
Diagose a Whirlpool or Kenmore Dryer that Keeps Running ...
? 3:05
https://www.youtube.com/watch?v=1B8kBGU4TVQ
Jul 24, 2014 - Uploaded by canyonman1963
If you would not mind another question: If I put the timer in timed dry, it does shut off. If I turn the timer to, say 30 minutes, I canhear the timer ...
Dryer won't shut off? - YouTube
Dec 26, 2015 | Dryers
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
Dryer will not shut off. could it be the timer?
Yes the time has a small motor on it and that is most always that. Carful the small motor can cost as much as a new timer.
Jun 06, 2010 | Kenmore 70172 Gas Commercial Dryer
Have a kenmore series 70 dryer. Won't shut off
Yes it deffinetley sounds like you may have a timer issue, if your timer stops and the dryer is running, or if the timer keeps going around and around this will be the problem, however there are thermostats inside the dryer and if you have it set on a HEAT and not a TIMED setting the thermostats won't advance the timer because they havent been set.Hope this helps
Thanks.
Nov 22, 2009 | Kenmore Dryers
Kenmore dryer timer never shuts off.
REPL/ YOU BROKEN LID SWITCH ,, IS ON OPEN POSITION REASON FOR NO T SHUTTING DOWN////
Nov 28, 2008 | Kenmore 27032
Kenmore 70 series dryer control/timer knob doesn't turn when running
THE TIMER HAS A SMALL DRIVE MOTOR THAT TURNS THE TIMER AT DIFFERENT SPEEDS FOR DIFFERENT CYCLES AND VARIES FROM BRAND TO BRAND BUT EITHER WAY YOU MUST REPLACE THE TIMER , EXPENSIVE FIX IF THE DRYER IS WORTH IT THAT SHOULD TAKE CARE OF THE PROBLEM
Aug 29, 2008 | Kenmore 60172 Electric Commercial Dryer
IT SOUNDS LIKE THE SWITCH IN THE TIMER IS BAD OR STUCK BEFORE BUYING ONE TAKE IT OUT AND TRY BUMPING IT AGAINST A PIECE OF WOULD OR SOMEHTING THEN TRY IT IF THAT DONT WORK YOULL HAVE TO BUY ONE
Feb 10, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 62602 Electric Dryer Logo
1,201 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
