Question about Philips 42PF9630A 42 in. Plasma Television
7 red blinks
TV turned off during the night (I fell asleep) and I awoke in the middle of the night to the power light blinking red 7 times in succession over and over again. Do you know what that means?
  • 2 more comments
  • Jack
    Jack Jul 16, 2008
    Philips 42PF9431D/31 BJ2.5U
    Red LED Blinks Seven times. Pulled cover. Rear Green LED blinks 4 times. Unplugging ribbon cable that feeds the x-main resets error. Error returns after extended power down period. (overnight)
  • Anonymous Apr 07, 2009
    my tv was working fine last night woke up this morning and my power light blinks 7 times then repeats,what happened?
  • 1armywifey Apr 07, 2009
    my tv was working fine last night,woke up this morning and the power light blinks 7 times and then repeats.what happened?
  • bobp73 May 11, 2010
    jdbouncer,
    Can you help? I have the same problem, that LED you're talking about is blinking 8 times. All help appreciated,
    Bob P.
    Problem Solver:
  • 12 Answers
I replaced the two badly swollen capacitors that were in the D3V3 circuit. The picture that mkinn posted shows that the capacitors that I replaced. They are directly centered in his picture. The caps that I replaced were 3300 Microfarad 10VDC. Radioshack does not sell the replacement capacitor but they do sell a 2200 Microfarad 35VDC Axial and a 1000 Microfarad 35VDC Axial. The two capacitors in parallel add up to one 3300 Microfarad capacitor. It took some effort but I was able to parallel the two capacitors using some jumper lead and heat shrink. I ran the TV last night. In the past it would not work after being shut off overnight. It worked this morning. Thanks mkinn.
Posted on Aug 03, 2008
    Problem Solver:
  • 7 Answers
Bad caps on SMPS board. Replace the SMPS and get a 1 yr. warranty on the new board. Otherwise try replacing these caps: http://i121.photobucket.com/albums/o229/garafrax/TV%20Repair/HPIM1458.jpg and
http://www.hotelkaveka.com/9944CU.jpg
Michael Kinnaird
Posted on Jul 22, 2008
    Scholar:
  • 72 Answers
Is the light blinking 7 times on front of TV ? If u take the back cover of the TV off you should see two leds on the bottom right of power supply turn on when u push the power button. When the TV go into error protection on the upper left of power supply you should see. A blinking green light. Please inform me of the error it flashes and ill will be able to help further. ( Serveral possiblilties it could be from audio, bad power,and faulty Y-main.)
Posted on Apr 30, 2008
I have an old, but very reliable, Sony Trinitron TV from about 2003. I fell asleep watching the other night and shut it off in my sleep. Now when I try to turn it on I can hear it trying to turn on, t
tried to unplugged the tv for a while to reset excessive voltages in the power supply as will as through the circuit. and then re plugged it again then power on, press any button. if still doesn't turn on take a look at the indicator if how may times does it blinks. it will help out to solved the main cause. the noise that you hear could be the relay in the power supply is trying to turn on. but something error in the circuit was being detected. so the blinking code can help us to determined where you gonna check.
Nov 17, 2012 | Televison & Video
Sony KV28FX60U wont turn on led flashes 7 times
Hello
  1. Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 21, 2012 | Televison & Video
I fell asleep with the tv on and when I awoke, the on/off red light just blinks and there is a "burning" odor
How many times does the light blink as thats an error code indicating which circuit has the problem. Let me know how many blinks and I will assist you with the problem.
Jun 13, 2011 | Sony KP-57WS500 57" Rear Projection...
Failure to start, period.
the whining you hear is most likely the color wheel
it need to reach a curtain rpm before the lamp will kick on
i will almost gurentee one of the colors is broken on the wheel
Mar 12, 2008 | Samsung HL-R5078W 50" HDTV
No sound ,fell asleep control on floor
Try not to fall asleep on the remote again. LOL :}
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 01, 2007 | One For All URC-3021 Remote Control
No power
your going to have to check out the main power supply or standby power supply. good Luck
Jul 25, 2006 | Samsung LN-S3251D 32 in. LCD HDTV
Philips 42PF9630A 42 in. Plasma Television Logo
1,244 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
