Question about Panasonic Lands Phones
The power went off and now I cannot see anything on the screen on the main phone. No contact numbers etc
I just removed the battery and relaced it and the phone had all the details as before.
Posted on Apr 30, 2008
I have a sharp 70inch led tv . All of a sudden the screen just went blue . Have sound etc . Cannot c menu or anything on screen tho except for mayb 5seconds after turning on . Any thing i can do?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 17, 2015 | Sharp Televison & Video
HELP! Olevia lt37hvs screen went blank. No Sound, panel buttons wont work. Backlight is only on on half of screen.
if you had audio i wold say its most likely the Tconn or its upper two connections to the Panel itself. But since you dont have any sound either I would assume its either the LVDS cable from the main board to the Tconn or the Main board itself as audio and video are produced on the main board, You can get replacement boards from www.tvrepairworld.com
Aug 12, 2012 | Olevia LT37HVS 37 in. LCD HDTV
My son turned off my phone and when I went to turn it on again the screen was black. I can't see any contacts or anything. I called the 1 phone number I had memorized and it dialed through.
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phones
Take care.
Mar 25, 2011 | Motorola Mobility RAZR V3
When I got a text a message came up saying I was running out of memory. I went and cliked to deleate my inbox and it started clearing the old messages but then it froze. I tried pulling out the battery and...
try to reset:
press "*" (star) and "3" and "on" switch together and wait until unit turns on - it will ask for format confirmation. remember to save all contacts (numbers etc) before doing format otherwise you loose them all...
regards
Feb 20, 2011 | Nokia 5130 Cellular Phone
The screen on my My Samsung SPH-m510 just went blank, white. I am able to receive incoming calls, however i have no means of seeing anything that is on my display, need it be main screen, contacts,...
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
Take care.
Jul 23, 2010 | Samsung SPH-m510 Cell Phone
I have a samsung phone and i need to reset my phone password. i cannot pull up anything
Hello. The phone password (unless you changed it at one point) is most often just the last 4 numbers of your phone number or SSN. Please try that. Once you have passed that screen you may reset to a different code again.
If that is not it, you should be able to take it to your mobile phone store and have them reset for you, but any contacts may be lost, etc. Phones are set this way to prevent an easy reset and use on lost phones, so there is no other "easy" way to do this without accidentally disabling or wiping the phone setup/activation.
Oct 29, 2009 | Samsung SCH-U470 Juke Cellular Phone
PC wont boot up after power cut
probably the power cut shorted one of the components on the computer.
Jan 02, 2009 | HP Compaq ProLiant DL380 G4 Server
My Nokia N70 cell phone Screen is white blank
formating your phone may fix the problem
Here’s how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Before formating make sure that your battery is fully charged. Copy all your important contacts, messages, calender, etc in your memory card and your phone should be fully charged window.google_render_ad();
Oct 21, 2008 | Nokia N70 Cellular Phone
Broken phone
Hi all,
I had simmilar problems ie screen ok when closed but fuzzy when slid open, screen going blank etc.
I replaced the flex cable that connects the screen to the main board and the phone now works perfectly.
Nick
Jul 17, 2008 | Samsung SGH-U600
Permanent blue screen display
I had the frozen blue screen twice. As a cowboy reset, I removed the battery for a minute, then put it back in. Worked for me, didn't erase my contacts or anything.
Oct 22, 2007 | LG VX5200 Cellular Phone
Lands Phones Logo
20 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
