Question about Garmin Forerunner 305 GPS Receiver
Charged my new nuvi 760. Unit will not turn on. Followed the steps in manual, held the on button to the left for 8 seconds, then turned it on and nothing. If I plug it back into the wall charger the Garmin name comes up for 2 0r 3 seconds, then goes black, back to the name, etc.
Try charge it for 4hrs on ur computer then take it outside and let it pick up a signel
Posted on Jun 07, 2008
  • 6 Answers
To power the unit back on, press the "Mode" and "Reset" buttons at the same time. Let go of those two buttons, press the power button, and the unit will turn back on."
Posted on Apr 29, 2008
The power off
  1. Make sure you are sliding the power button all the way to the left.
    • If the unit does not respond, it may be that the battery is not charged.
  2. Connect the nuvi to a power source such as the USB cable and your computer.
  3. Reset the device, if the problem persists, by sliding the power button to the left and holding it in that position for 10 seconds
    • This resets the unit and prompts it to power on.
  4. Contact Garmin Support if this does not solve your problem at www.garmin.com
Jul 04, 2010 | Garmin Nuvi 760 Car GPS Receiver
No sign of life from my gps
From Garmin's website:
If still unable to breathe life into your 760, contact "SUPPORT" at www.garmin.com. Please rate this reply if helpful - good luck!
Jun 28, 2010 | Garmin Nuvi 760 Car GPS Receiver
My Garmin Nuvi 760 screen goes black after 8-9 seconds. I have replaced the fuse in the charge cord. Someone recommended that I remove the battery and turn the power button on for ten seconds to reset the...
Do not open the nuvi, the garmin site recommends the following method instead:
If this fails to solve the problem, contact "SUPPORT" at www.garmin.com.
Please rate this reply if helpful - good luck.
Jun 20, 2010 | Garmin Nuvi 760 Car GPS Receiver
My nuvi 760 will not take a charge, turn on, or do anything when plug into my computer. I do need to register it it has never be.
Jun 09, 2010 | Garmin Nuvi 760 Car GPS Receiver
Turned the Nuvi 750 off while searching for a POI and now it will not turn back on.
Slide the power key to the left for 8 seconds plus, to reset it
or 30 seconds plus, to try calibrate the screen.
Regards.
Jun 22, 2009 | Garmin Nuvi 760 Car GPS Receiver
Won't switch on
I had a similar situation. My 760 could not be switched on, despite a fully charged battery. The hard reset procedure (power button held for 8 seconds) fixed my problem.
Apr 07, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Nuvi 760 will not turn on !!
I just had the same issue, after using the unit for 11 months.
WOULD NOT power on... and i freaked.
This is what solved it, no matter how strange it sounds...
I held the 'power switch' to ON for 20 secs, then it came on again.
I hope this works for you as well!
-Drew
Feb 18, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Nuvi 760 suddenly stopped working - will not turn back on
Try holding the power slide to the left and holding it there for 8 seconds. If that doesn't work, try charging it via your PC & USB cable. If that doesn't work, try a mains charger if you have one (I had to do this with mine). Good luck!
Dec 30, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin 760 : no satellite signal found at all even in open space
Have you tried performing a full Reset? Slide the Power key to the LEFT, and hold for at least 8 seconds. Then turn the nuvi back on while outside in clear view of sky. It should take < 1 minute to calculate a position.
If not, you may have a defective unit in need of repair.
Jul 16, 2008 | Garmin n?vi 760 GPS - Piano Black
Garmin Nuvi 760 Frozen
Hi!
Have you tried reading the manual?
Availlable here:
http://www8.garmin.com/support/userManual.jsp?market=4&subcategory=41&product=010-00657-10
Suggest you try the following:
Holde the on/off switch in the on (left) position for 8 seconds, then release.
The unit should now power up as usual.
It worked for me!
Good Luck!
May 27, 2008 | Garmin GPS
Garmin Forerunner 305 GPS Receiver Logo
50 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
