Panasonic PT-51HX40B convergence issue
I'm stumped trying to fix shot convergence on my Panasonic PT-51HX40B.
I replaced the STK-392-110's with no change in convergence.
I ordered and installed Sanyo STK-394-160's with still no convergence.
I checked all of the 20-ohm 1/10w resistors, values look good.
The voltages at the STk's look good.
I have no convergence control at all.
Any ideas or schematic would be appreciated.
Thanks,
Dan
  • Dan Smith
    Dan Smith Nov 15, 2008
    Replaced STK's with a new set. Still no convergence. Must be something else.
    If anybody has schematic or service manual, it would be helpful.
    Thanks,
    -Dan
  • 4 Answers
Hi.....
Bit of a long shot but have you tried this??
http://oreilly.com/catalog/htheaterhks/chapter/hack12.pdf
Hope it helps!
Richard
Posted on Jun 30, 2008
Panasonic PT-51hx40b projection TV powers off when I try to turn it on
Not sure if the transformer is bad or something on secondary side is pulling the voltage down--if replacing it cured the issue you did good.
If not try to disconnect at source on secondary side to see if with no load the voltage comes up.
Looking for either the xfmr to be bad or something shorted pulling the voltage it creates down.
May 14, 2012 | Panasonic Televison & Video
What causes this
Hi, thank you for visit fix ya.
Do you have problems with you STKs ICS convergence.
Replace stk 392-110, use stk 392-150 ( better).
For parts, go to:
http://www.encompassparts.com/
Thank you
Jul 23, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Green rainbow streak on bottom of TV PT-47Wx49E
If Convergence on setup dosen't work, And you think its not STK Convergence chips!, Then "Yes" It more then likely will have a few open Resistors!... (Near STK chips)
Jun 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PANASONIC PT-51HX41E
The convergence amps have most likely failed. That unit takes two STK392-110 (Sanyo) amps. For more reliability I'd have them changed using an STK392-150. They have a greater amperage and higher heat tolerance.
It's clearly a job that you want a qualified shop to do.. Call around and get some off-the-cuff estimates on what they charge to change out the convergence amps and tell them that you would prefer they use the 150's instead of the 110's.. They'll probably wonder how qualified you are. :)
Bill
Nov 13, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic Projection TV PT-47WX49E convergence ...
may not be convergence may be a bad stk for convergence if that style if so try stk
Oct 28, 2007 | Panasonic PT-47WX49 47" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Convergence issue
so you keep buying new tvs each 4yrs or so..all about money..
Jul 28, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
200 people viewed this question
Top Televison & Video Experts
Electro Med Services...
