Question about Whirlpool RF368 Electric Kitchen Range
Burner gets too hot
Once you turn the switch to 5 the burner stays on. If you turn down to 4 to 1 the burner stays on as well. Only after the burner is in the off position and cooled down will it be able to go to 1-4 again.
  • wbeau1435 Feb 14, 2009
    The burner should stay around a certain temp. when you set the dial. 1,2,3,4,ect.. with me the burner keeps warming up getting hotter and hotter. it will not level off until you turn the burner off . even if you turn the dial to a lower number.
5 Suggested Answers
  • 1314 Answers
SOURCE: Burner heating when it shouldn't.
change the switch contacts sticking
Posted on Apr 02, 2008
huuum
  • 750 Answers
SOURCE: whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Posted on Oct 03, 2008
  • 11 Answers
SOURCE: Kenmore: 790.99012102, right front burner will not turn off.
Please confirm your model number. If 79099012102 is the correct model number, there is a POWER RELAY BOARD located on the back of the unit behind the bottom metal panel. 316239403 is the part number if your model number matches the one listed in my response. If it is different, than my part number will not be correct.
Posted on Jan 15, 2009
  • 11 Answers
SOURCE: why does the hot service light stay on all the
could be a defective surface element control or INF switch control, replace them, you should be good
Posted on Oct 28, 2009
Burners do not turn down to selected temp and food burns
I wish I had good things to say about GE but I don't. Probably the burner control is no good. Contact GE and get support due to the fact somebody can get hurt.
Nov 16, 2013 | GE Profile PS968 30" Slide-in Electric...
Burner will not get hot enough
When the burner arced out it probably also ruined the switch. Most switches on a standard electric range have 5 wires. 2 wires to the burner. 2 hot wires from power and a smaller wire which connects to the indicator light marked P. It is easy to test the switch Unplug the stove. Turn the suspect switch on wide open. Check for continuity between the 2 terminals going out to the burner marked H1 and H2
If you cannot get a reading then the switch has failed. Note: when replacing the switch usually on most stove the replacement will not be or look like the original HOWEVER it will still have L1 and L2 H1 and H2 and P but the terminals are not always in the same order. If you fail to correctly connect the new switch you will fry 2 switches when both get turned on. Ouch!
Aug 30, 2012 | Kitchen Ranges
Water won't get hot, code c2 11
1-866-720-2076
Available between 7AM - 7PM Central Time
7 days a week
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
Burners will not disengage after shutting off Hot Water.
Ok the way this system works is from a pressure and flow switch. The pressure switch picks up the slight drop in pressure when the hot side water is turned on then turns on the burner. The flow switch measures the amount of water flowing and adjusts the size of the burner to the amount of water flow. So a couple different things might be happening. The flow switch might be sticking causing the water heater to throttle down the burner but not off when the water flow is off. Or the gas control valve might be by-passing gas when off causing the burner to stay on even when the demand is off. Run the hot water on high demand then turn the water off. If the burner is still on try banging on the water heater with your hand and see if the burner shuts off completely. If it does the gas control valve might be by-passing. You would also need to check and see if the pressure/flow switch is giving any voltage signal changes when the water flow is off. These tankless water heaters are more comlplicated to work on than a standard water heater and you may need a professional's help...good luck
Sep 23, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Element does doesn't switch off.
What your going to have to do is replace the infinate control for that burner. ( thats the control you turn to sw it from high to low heat )
good luck
Jan 07, 2009 | Kenmore 96212 / 96214 / 96219 Electric...
Burners go out before the fan starts
that makes no sense? the door on does exactly the same thing as you holding the switch closed and neither has anything to do with the problem you are describing. if door were off nothing would happen. if door was on ,nothing would happen unless the switch was closed. it may be coincidence, but sounds like the unit is not proofing the flame. look for a little needle like sensor that protrudes into the flame path in front of a burner. when the burners light it senses flame and tells gas valve burners lit and its ok to stay on. then heat builds and the fan is briught on. once in a blue moon the overtemp sensor trips open prematurely as soon as the burners start to heat up. it is a little wire in , wire out sensor above the burners that protreudes into the bulkhead above the burners. if it is cold and open its bad. if you jump it and burners light and stay lit and fan comes on its bad. fairly cheap and easy to replace. you may have an old fan limit switch the rotates like a spring to bring the fan on as it heats up, then turns off burner if its gets to hot or is set to low. it also turns fan of as burners cool down.
Dec 05, 2008 | Heating & Cooling
Burner gets hot even when not turned on
sound like you have a shorted element, it will stay hot but not high heat hot (glowing) red, other posibility is bad infinate control switch that switch could be bad
Apr 13, 2008 | Cooktops
Burner with intermittent feature won't light once hot; spart OK - - no gas.
mdpaul, sounds to me like 1 of the burner switches for the ignition is sticking. There is a small area where the switches turn to that shuts down the ignition. If the switch has failed from heat or is out of position, this can cause this issue. The switch is designed so when you turn the knob it closes the contact. The switch has to be locked into postion on this model. There is a push fit type retainer that locks this down. Pull the knobs off and turn with a pair of plyers to see if one is moving around. If so then with a deep socket, see if you can tighten the retainer by pushing down on it. Hope this helps.
Feb 03, 2008 | Thermador SGS36GS Gas Cooktop
Whirlpool RF368 Electric Kitchen Range Logo
149 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
