Cannot change keyboard to be able to use puntuation keys such as question mark and apostrophe
    Genius:
  • 3,587 Answers
Change it? those are used with the Shift key pressed first..
Posted on Apr 28, 2008
How to use apostrophes
Apostrophes are on the key to the left of the 'enter' key. Shift + this key will give you "
Nov 13, 2013 | Computers & Internet
How to use accents when writing in Spanish in a Dell Precision m4500 laptop?
On Windows XP
  1. Log On
  2. Click the Start button
  3. Click on Control Panel
  4. Click Regional and Language Options - a new window will pop up
  5. Click the Languages tab
  6. Click on the Details button
  7. Click the Add button - a new window will pop up
  8. Select United States-International (keyboard layout menu)
  9. Click OK
  10. Click Apply
  11. Read the instructions for "Using the U.S. - International Keyboard" below.
Note: You will now have a keyboard icon on the taskbar (usually on the right side). To switch between keyboard layouts click the keyboard icon on the task bar and choose which layout you want to use. Changing the keyboard layout will only affect the log on profile used. No other users will be affected.
Windows Vista
  1. Start-->Control Panel-->Clock, Language, Region-->Change Keyboards
  2. New Window: Click the Change Keyboards button
  3. New Window: Click the Add button
  4. Select United States-International keyboard
  5. Click OK
  6. From drop down menu (Default Input Language) select United States International
Using the U.S. - International Keyboard If you followed the above directions carefully, your keyboard will now react slightly differently than it did before. First of all, notice that if you strike the single apostrophe (') key, nothing happens. To type the single apostrophe now, you must strike the single apostrophe key and then strike the space bar. When you strike the spacebar, the apostrophe will appear.
The next thing to note is that the quotes (") key behaves the same way as the apostrophe key. You must first strike the quotes key and then strike the space bar in order to create the (") symbol. These two minor inconveniences are more than made up for by the ease with which you can now type the special characters.
To type the special characters, two keystrokes are required. To type the ?, you need only strike the apostrophe key and then the letter a. The other characters are just as easy:
  • ? = ' + a
  • ? = ' + e
  • ? = ' + i
  • ? = ' + o
  • ? = ' + u
  • ? = ~ + n
  • ? = " + u
To type the special punctuation characters, you need to hold down on the Alt key while you strike the appropriate punctuation mark. On some keyboards, only one of the two Alt keys will work for this.
  • ¡ = Alt (hold down) + !
  • ¿ = Alt (hold down) + ?
Using Cryptic Codes If, for some reason, you don't want to change your keyboard, you can always type in the troublesome cryptic codes. Using this arcane system, the following codes apply:
  • ? = Alt + 0225
  • ? = Alt + 0233
  • ? = Alt + 0237
  • ? = Alt + 0243
  • ? = Alt + 0250
  • ? = Alt + 0241
  • ? = Alt + 0252
  • ¡ = Alt + 0161
  • ¿ Alt + 0191
When using this utterly out-dated system, there are two important things to remember. First, when you type in the numbers, some keyboards require that you use the "numeric keypad" located to the side, rather than the numbers along the top. Second, on some keyboards, only one of the two Alt keys will work for this.
May 02, 2011 | Computers & Internet
When I strike the apostrophe, quotation marks (or double appostrophe)appear. When I Shift + apostrophe, double quotations appear. Same thing happens with the tilde key. So far just these 2 keys...
Sounds like a defective keyboard. I seen issues when pressing a button it will trigger another key to be pushed or nothign displays at all. Try replacing keyboard since they are relatively cheap. othersie maybe a software issue
Mar 03, 2011 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Acer aspire one keyboard. When I use the apostrophe key, I get an accented e instead. Why and what can I do to change this (I get a capital E accentedwhen I hit the question mark key).
you have chosen the wrong settings when you configured your keyboard .Choose correct keyboard layout from there-it should work alright
Sep 10, 2010 | Acer Aspire One PC Notebook
Keyboard problems
Sounds like the wrong keyboard driver installed. Control Panel>Region>Keyboards & Language
Oct 04, 2009 | ASUS 90-A4C1K1000 Keyboard
Symbols gone crazy
The keyboard appears to be defective, but if you replace it and you still have issues, then the matrixing chip on the motherboard is bad and you will have to change the motherboard as well. Let me know, and vote.
Jul 02, 2009 | Acer NSK8458AN Keyboard
Cannot get apostrophes or question marks
I just figured this out. Hold down your left shift key, then press CTRL. It may take a couple of times for it to work, but it will eventually.
Oct 08, 2008 | Compaq Keyboard
Messed up keys
try hitting the left alt and the left shift button together, then try it out by pressing shift question mark. I had the exact same problem and i think you can alternate between french and english keys by hitting these two buttons together.
Jan 18, 2007 | BenQ X805 Wireless Desktop Companion Pro...
Keys on keyboard
Try changing the language from English(US) to English(UK)
The Yanks have not only a different language - but also a different keyboard layout to us Brits :-)
Aug 12, 2006 | Gateway 2520915 Keyboard
Computers & Internet Logo
David Payne
David Payne
