Question about D-Link AirPlus DI-524 Wireless Router
All-in one computer recognizes wireless printer/scanner but will not work
  • elfa May 11, 2010
    Need more info on the set up to help.
  • Kevin Flannagan
    Kevin Flannagan May 11, 2010
    Do you have a wireless router running and have the wireless printer and scanner running off of the router? Also, what kind of wireless connection are you using for the printer/scanner?
    Genius:
  • 1,269 Answers
Make sure printer driver is installed on your computer
Posted on May 17, 2008
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
Jan 22, 2015 | Office Equipment & Supplies
Scanner is disconnected or Turned off.
Try going to manufactures web site and downloading drivers for the printer from there. Also you might check your device manager to see if the unit is being recognized by your computer. it should show up iunder USB or Printers. I had an Epson that did the same thing but mine was a wireless and I had to re-establish coneection and go through setup again to have my IP address recognized. Most of the time plug n play will pick up the new device.
You might also try running security and windows updates on your computer, there might be an update that is keeping the computer from recognising the printer anymore.
Its just a start of what could be going on, hope its an easy fix.
May 29, 2012 | Canon PIXMA MP495 InkJet Printer
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Cannot coonect SCANNER (HP Officejet 6500 wireless) to my Windows
I have seen alot of problem/posts concerning HP AIO's and software issues. Typically some of the functions won't work or not recognized by solution center. Try a complete uninstall of all associated printer software, run registry cleaner if you have it, restart, then try completely uninstalling your Antivirus/firewall software. I have seen that just disabling Antivirus/firewall still causes faulty installations. Now, reinstall your printer software/drivers and connect cables only when told to do so. Some reason the AV/FW software blocks some of the AIO's apps from completely installing.
Hope this works...Good Luck!
Jun 12, 2010 | HP Officejet 6500 Wireless All-in-One...
Scanner does not work
Try uninstalling the scanner driver. Then unplug the scanner. Reinstall the scanner driver on the computer and then plug the scanner back in (USB connection).
Jul 30, 2009 | Canon PIXMA MP470 All-in-One Printer
Cannot get scanner to work with Vista or XP
you will have to uninstall the scanner drivers from the computer in the control
panel>scanners..then uninstall the printer drivers from the orinter in the control
panel and then run the wireless setup wizard on the printer then try reinstalling the drivers and the s/w using the disc that came with
the printer......see if works
Feb 24, 2009 | HP Photosmart C7280 Laser Printer
Canon pixma MX310 scanner not working
I read somewhere that the printer/scanner must be plugged directly into the computer in order to scan.  I tried it, and it works.  Printing can be done wirelessly, but apparently not scanning!
Oct 09, 2008 | Canon PIXMA MX310 All-In-One Printer
Scanner not recognizing software
I also have the same error and same 2015 printer in addition to my 7210.
Anyone figure this out? HP tech level 2 support cant figure it out.
May 23, 2008 | Office Equipment & Supplies
Computer would not recognize the scanner
go to control panel, add hardware, search while the printer in connected, as far as im think you computer has disabled it. all you have to do it activate it.
May 12, 2008 | Office Equipment & Supplies
try opening the scanner from the START-ALL PROGRAMS-HP-ALL IN ONE
Jan 11, 2008 | HP OfficeJet 7410 All-In-One InkJet...
D-Link AirPlus DI-524 Wireless Router Logo
26 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
