Question about Brother MFC-9420CN All-In-One Laser Printer
Paper jams out of the fuser
I get jams out of about 1 out of every 30 pages printed until I let it cool down and them it works fine until I print alot of more pages
  • ep4545 Jul 04, 2008
    Every 2 or 3 copies I am getting a roller fusion jam. any suggestions.
I had constant jamming problems (mostly with pages with a lot of color coverage) when I was refilling toner cartridges with cheap refill kits off of ebay. Switched back to new brother cartridges and have not had a jam since.
Posted on May 14, 2008
Samsung SCX 4623F " Paper Jam Inside"
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 05, 2016 | Office Equipment & Supplies
Frequent Paper Jams in Brother HL-2140
Every 120,000 pages, the paper feed rollers, fuser, transfer roller, and OPC belt cartridge should be replaced, usually by a trained techncian.
Fuser and OPC belt units are customer-replacable.
The multiple feeding of the paper into the printer is due to a worn paper separation pad. part no. LM0711001. If the machine is picking up the paper okay and the jams occur solely from multiple sheet feeding, then this part is probably all you will need. The steps required to access and remove & replace the separation pad unfortunately is about 10 steps. Better consult a tech.
Oct 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Won't let me fax, copy or print. it tells me paper jam 2 look in
paper jam 2 generally denotes the fuser unit. thats at the back, the bit that heats up, theres a flip up/down cover that once opened should show you if theres any paper in there, also check the sensor, little black arm, move freely and be sprung, if the sensor is missaligned it will denote a paper jam even when there is none be careful to let the fuser cool down, printer unplugged for 10 minutes or so, 180 degrees will hurt.
Sep 24, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Paper jam after 1 page prints
fuser paper out sensor faulty.req new fuser.
Jun 20, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
P3005n prints one sided fine, but jams in fuser on duplex
Lower the rear door ALL THE WAY DOWN past the 2 stops
Remove the 2 screws, pull off rear cover
Remove the small left rear cover and small right cover
Unplug the 2 small plugs on the right side.
Remove wires from white clip.
Remove large white plug on big circuit board
Remove 2 screws and pull out fuser
Look for a switch knocked off
Feb 13, 2009 | HP LaserJet P3005n Printer
Paper jam, no printing, constant error
you can Visit the Konica Printer Knowledge base, which explains on a .pdf and with a video, how to clear the basic fuser roller jam with a piece of card.,no printing,etc click the link and put in your product type that wil take to faq page youll see the issue and solution elaborated
and work your way through the links.hope this helps
Oct 02, 2008 | Konica Minolta magicolor 2400 Laser...
Brother 5250
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
  • May 27, 2008 | Brother HL 5250DN Laser Printer
    Paper jam 580
    You know what I would try, look in the fuser unit and see if any paper ripped off and got stuck in there. Wait until it's cooled down, but usually if you have to pull paper of of there, little pieces can get caught in there. Also, you may have a full sheet in there, I've had people leave and entire sheet in the fuser all scrunched up and the machine print fine for another 100 prints and then have an error and the paper coming out looking like it almost caught fire.
    That's where I would look first if there isn't anything in the print path under the toners, etc.
    Oct 27, 2007 | OKI C5100n Laser Printer
    Brother MFC-9420CN All-In-One Laser Printer Logo
    137 people viewed this question
    James Cagle
    James Cagle
    Jim Keysor
