When you hit print, it says there is a problem. the printer and the computer seems to be not conecting
IT DON'T DO ANYTHING OR IT WILL SAY ,PRINTER IS NOT COMMUNICATING OR UNPLUGG AND REPLUGG USB,POWER,AND RESTART COMPUTER I'VE DONE ALL THIS AND I JUST DOT A NEW CARTRIDGE.I'VE ALSO DOWNLOAD THE DRIVES FOR MY LEXMARK FOR WINDOWS VISTA.
Posted on Apr 29, 2008
2 Suggested Answers
Evildice
  • 217 Answers
SOURCE: My Samsung printer is conected on other computer,and not printing
try to reinstall printer driver.
Be sure printer IP adres is correct.
Good Luck!
Posted on Jun 21, 2010
Document failed to print
There are some printer order pending in your computer. For these reason you may to remove printer order. To cancel print order follow these proces
Start - printer and fax> printer icon double click> show window> then delete print order.
Now unpluge all the conection both usb and power. Wait few minites, and then reconect conection again
Thank you.a
Now , op,
May 19, 2011 | Office Equipment & Supplies
I lost my soft ware for my printer lexmark x75 and i can seem to conect to my computer i try everything
You can download the software at lexmark.com. Try re-installing it and following the promps. Hopefully you'll be able to print again.
Mar 19, 2011 | Lexmark X75 All-In-One InkJet Printer
I cleared a paper jam from an HP Deskjet 6122, but now it won't respond to commands from the computer. I've restarted the printer and the computer. Now the print manager just says it's...
First things frist. If the printer is conected with a USB Cable to your computer, try removing and reinserting the usb cable. To make sure that it is properly connected.
You might just have unintentionally got the printer in offline mode. Now follow this steps:
To check if it is offline. 1. Go to devices and printers (7), Printers and Faxes(XP), Printers (Vista) 2. Double click on the printer icon 3. Click the option that says Printer on the upper left corner of the window that pops up.
Th only options that you need checked is the one that says Set as Default Printer. For any other options that has a check mark. Click on them to remove the check mark.
4. Click Start again, on the search box type in services.msc, hit Enter. For XP, CLick Run, and type the same thing and then hit ok. 5. A window should pop up with the list of services for your computer. Look for Print Spooler in that list. 6. Right Click on the Print Spooler and Click Stop. 7. Right Click on the Print Spooler and Click Start.
Restart your computer. Try printing again.
Feb 03, 2011 | HP DeskJet 6122 InkJet Printer
Good Luck!
Jun 21, 2010 | Samsung ML-2251NP Laser Printer
Toshiba E-Studio 160 network print?
Go to Control Panel -> Printers. Select Add Printer... When it prompts for a local printer or a network printer, select network. Follow the prompts from there.
Mar 29, 2009 | Toshiba E-Studio 160 All-In-One Laser...
Printer sharing problems
Can you see the printer from the networked computer? Have you gone into the printer properties and set it to share? Right click on the printer in printers and faxes and select properties. Click on the sharing tab and clickn on the circle next to share this printer. (Windows xp)
Jan 12, 2009 | Lexmark Computers & Internet
Printing error hp c2780
It seems to be an issue with the printer drivers on the computer,You need to check for
any queued documents,if they are there,if yes,delete them,if not go ahead and
unintsall the printer drivers from the control panel>printers and faxes and then
restart your computer and then try a plug and play if its a USB printer
Nov 29, 2008 | HP Photosmart C7280 Laser Printer
Ricoh 1018d not print with lan conection
Hi Usama,
I had the same proplem as you when i installed pcl6 driver on my ricoh 1085
I solved but by uninstalling pcl6 driver and installing pcl5e
for your 1018d try this driver for windows XP D O W N L O A D H E R E
BTW.
about using 1085 as a scanner ,
I don't know what is "scanner interface drive board" ?
more help please.
Oct 23, 2008 | Ricoh Aficio 1085 Laser Printer
No printing
has your copier been set up with pin numbers or department counters, if so you will need to enter a valid pin no. in printer driver properties. Also go into printer properties and check printing preferences aswell as properties for any paper size/tray issues and remeber to apply any changes.
Mar 05, 2008 | Office Equipment & Supplies
Not printing
Do you mean your printer is connected to a usb port at back of computer? Obviously it must be or no communication would occur!!! What error messages are you getting?
Aug 08, 2007 | HP DesignJet 3000cp InkJet Printer
k24674
