Question about Vacuums
My old Samsung CRT TV has strange blue dots on the top left corner. Is it because it's next to a speaker? when I move it the dots go away after a while.
    President:
  • 1,673 Answers
Yes, speakers will cause the picture to magnatize amd will cause this distortion. Keep the speakers at a distance to prevent this from happening.
Posted on Apr 29, 2008
Neato robot turns on, fires up vacuum/brushes, but won't move - no error messages. What gives?
I have a Neahis to Botvac 85, had also problem, it started up then stopped. It is 2 or 3 years old, don't remember. but it started to ack very strange with the battery. then this start/stop problem came. I ordered a new originial battery and thought it should solve the problem but no it didn't After some time I decided to try again. Started Neato and it stopped after some time, then I wanted to see if the lidar was rotating so I removed the blue cover over the lidar and could see that it was rotating, then I touched it little bit and the neato started and started to clean my floor. so try this.
Sep 12, 2014 | Neato XV-21 Pet & Allergy Automatic Vacuum...
DC16 charger output 28VDC Battery 23.6VDC only runs 1-3 sec what is wrong
Hi Rene,
I am sorry to hear that your DC16 handheld seems to have a short runtime.
This issue is generally the result of the filters needing to be washed or not being seated properly in the machine. If the machine is being used regularly, the filters should be washed monthly otherwise it will impact the performance of the machine.
To inspect the filters follow the steps below:
Remove the canister and separate the nozzle from the main body of the machine by pressing the silver button on the top of the machine.
Remove the pre-filter.
There are two portions to the washable pre-filter a blue sponge and a white scrim that has blue plastic.
In the lower right hand corner of the blue plastic is a small silver disc. Opposite of the small silver disc is a hole that should slip onto a molded plastic post in the main body of the machine.
While holding the handle of the machine in your right hand locate and lift up on the small "lip" on the left-hand side of the main body where the vents are.
The rectangular blue sponge is your post motor filter.
These filters should be washed once a month in cold water (no soap) and left to dry at room temperature for 24 hours or more.
If any gray is visible on any part of the filters they need to be washed.
When replacing the pre-filter into the machine it is important that the blue sponge face away from the motor and the small silver disc on the white portion be positioned in the lower corner of the main body.
If the steps above do not fully resolve the problem, please call us directly at 0800 298 0298 (UK) or 1-866-693-9766 (US).
Best wishes,
Jessica
Nov 29, 2012 | Dyson DC16 Root 6 Bagless Handheld...
No power,fuse ok . i want to remove the casing but cannot find how,
If it's a sealed plug you won't?? cut off old plug and fit new standard plug brown to fuse blue to terminal on left yellow/green top terminal!!
most sealed plugs have fuse showing on bottom which just lift out!!
Jan 17, 2011 | Vacuums
I want to fold three blue strings into a plat, what steps must i follow?
Lay out the strings next to each other. Tie all three into a knot or otherwise secure them. Take the one on the left and fold it to the center, next, take the string on the right and move it to the center. Repeat, repeat, repeat.
Aug 16, 2010 | Vacuums
Drive not working on my hover sweeper handle seems very loose
How to Change Actuator on Hoover Self-Propel vacuum Cleaner - Step by Step This is a notorious problem for the Hoover WindTunnel Self-Propelled Models. What happpens is that the handle of the vacuum that controls the transmission is controlled by an actuator arm that is attached to a cable that runs down through the machine. The poor design of this self propelled system is design in such a way that if you pick up the vacuum using the handle (this is natural way to do it, I'm guilty of this as well), it puts too much strain on the actuator arm that controls the self-propelled mechanism, and causes the nut, washer, and screw to strip right out of the actuator arm. This explains why your handle is so loose. You may verify this by looking at the gap between the upright body, and the lower agitator housing, right where the vacuum pivots when you step on the handle release pedal. You should see when you move the handle up and down that the cable and nut are the only parts moving, and you should be able to see where the nut did sit inside of the actuator arm before it was stripped. The good news is that this is a relatively inexpensive part, and the repair is really not that difficult.
I will explain step by step, and include pictures so that you may see how to replace the part that's broken.
Always be sure your vacuum is unplugged from the electrical outlet before performing any kind of service!
Tools and materials:
Torx bit or driver size T-25
Flat blade screwdriver
Phillips screwdriver
Actuator arm – Hoover part number 43143046
Here's the picture of the part that probably needs to be replaced.
Step 1. Place your vacuum cleaner upside down with handle resting on the floor and brush roll housing resting on a work bench.
Remove 4 screws from rug plate and set rug plate aside.
Step 2.
Remove power drive belt, brush roll belt and brush roll.
Step 4.
Remove 6 screws as shown. Also remove duct hose cover and small plastic section that was under brush roll in upper left corner.
Step 5.
Place vacuum right side up on top of work bench with handle all the way back. Using a flat blade screwdriver; gently pry the top cover away from the bottom housing in the area shown by(#1) arrows. Leave the 2 adjustment knobs(#2) in place.
Step 6. If the self-propel adjustment cable HAS NOT broken away from the actuator arm, proceed as follows; mark the position of the cable(#1) in relation to the cable retainer with a black magic marker to avoid having to readjust the cable position. Remove the screw(#2) (usually a Torx T-25 size screw) and cable retainer. Next, using a flat blade screwdriver; slide the ‘C’ ring (#3) off the metal post. Bend the metal bracket up off the post just enough so you can lift the damaged actuator up and off the post. Slide your new actuator arm back over the metal post. Slide the ‘C’ ring back over the post.Lock the self- propel cable back in place with screw and retainer. Test to ensure the power drive is adjusted correctly; CAUTION, YOU ARE ABOUT TO COME VERY CLOSE TO MOVING MACHINERY, NO NECKTIES, NECKLACES, LOOSE SHIRT TAILS,UNACCOUNTED FOR TOOLS OR CLUMSY FINGERS ARE ALLOWED FOR THIS NEXT STEP!!! Reinstall the power drive belt, plug your vacuum cleaner back in and turn it on. Check to make sure the handle is in the neutral position; observe that the power drive is NOT moving. Push the handle slightly forward. You should see the power drive wheels move in the forward position. Pull the handle back, you should see the power drive wheels move in the reverse position. Some finer adjustment may be necessary.
If the power drive cable has broken away from the old actuator; just try to get the new actuator arm as straight as possible. Using the handle and while observing the cable moving back and forth through the retainer area; move the cable all the way forward, then pull it all the back, try to gauge where the middle of the forward and reverse position would be and lock the cable down. Perform testing procedure as in previous paragraph. Again, some fine readjustment may be necessary.
I hope that this was helpful. I'm am 99% sure that this will fix your problem, but if for any reason it doesn't, please feel free to use the Clarification Request Form here on Fixya, and explain why this didn't work. Please feel free to logon to our website, http://www.govacuum.com/ if you need any parts for your Windtunnel.
If you can't find a particular part, more then likely we have it, just feel free to give us a call.
If this repair was hepful to you please be sure to rate the repair as helpful by clicking the Thumbs Up Icons in the top right hand corner.
Thanks again,
Chris J.
GoVacuum
Mar 27, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Wiring diagram s3755 hoover
Today I shortened my hose by 4" to get around a tear problem. You can use an Ohm meter to find the right 4 wires. When looking from the top of the canister with the hose heading to your left, the wires should be:
White (furthest connector away from you)
Black - to the switch
Red
Blue
With the Red and Blue going to the speed con trol curcuit board.
Aug 05, 2009 | Hoover S3755 WindTunnel Bagless Canister...
How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Jan 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover brushes wont turn
Is the shaft on the brush block or did it break off, if it did, replace the brush block. On the top, left rear corner is a lever that moves baack or forward depending on the handle being upright or tilted back for usuage. Is it moving? If not then you have a problem there. Otherwise if the square hole doesn't move when it is turned on, and the lever is switch to the on position, then replace the turbine.
Jul 16, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover u5209-906 upright
1. You have to lay it on its front so you can unscrew the two screws in the underside (these are on the plastic panel covering the brush). There are also two holes for you to use a screwdriver in right next to each screwhole. Lever the plastic tabs in the direction indicated next to the holes (I think it is towards the motor). This case should then click up and away N.B. There are 3 tabs fixed into the cover on the front edge of the vacuum head. Be sure you don't snap these off.
2. You then need to use the foot pedal at the back of the vacuum to lay it flat and using a flat bladed screwdriver lever the top cover of the head away from the frame on the two back side corners and across the front of the head. The top case should now be able to come off.
3. The belt should now be able to slip off the motor spindle and off the brush.
Repeat the procedure in reverse once the new belt is on.
Cheers.
Apr 13, 2008 | Vacuums
Changing belt on hoover runabout
Found this info on the web...haven't tried it yet
Sep 07, 2007 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
