Hitachi ultravision dlp projection tv
I have a translucent blue spot on the screen. It is in a fixed location. Does this indicate the lamp needs replacement, or something else? Thanks- mark
No you need a light engine, possibly covered under a recall, other wise its like your cars block is cracked
Posted on Jul 27, 2008
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
When i turn on my tv, a reddish-orange light shows up covering the left side of the screen. Any idea what that could be?
Since the model indicated (55vg825) is a DLP which uses a lamp--it does sound like you have a damaged "optical light engine" which is a expensive repair---confirm model number to me and or Contact Hitachi about a possible recall or repair on that model.
Mar 11, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
I need to replace the lamp on my projection tv HITACHI ULTRAVISION 53UDX10B. it's difficult to find online. i will need to have the part number for the lamp.
Your model is the DP-15 chassis which is a CRT projection so you do not have a lamp like the DLP models do. You have three CRTs Red, Blue and Green instead of a single lamp.
Jun 09, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi ultravision 50V500A screen dim
The model indicated is a DLP rear projection and uses a "lamp" for brightness.
If it has not been changed for a while it should be on the right side of the set behind a removable plate. Check your owners manual if you have it.
Life span varies but 2,000 hours is normal.
Let me know if you need any further assistance as I am here to help.
SD TECH
May 14, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Lamp went out on DLP TV
Did you replace the lamp door? A flashing red light is an indication of a door open or an impropely seated lamp. Try removing the lamp and reseating it. Reinstall the door and try turning it on again. Also, you may want to unplug the TV from the power source, count to about 20 and then plug it back up again. This may reset the TV.
Good luck
Aug 09, 2009 | Hitachi Televison & Video
Remove screen from Hitachi Ultravision
underneath screen remove screws holding screen in place ,it should then slide upward and off.
Dec 08, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
562 people viewed this question
Top Televison & Video Experts
