Also wont turn on unless i move it around slowly then it will turn on once it is on it is fine in every way will turn of and on no problem but if it sits for a couple of hours then it has the same trouble turning back on
I think you have problem wiith the AC-connector behind your laptop.its not seated properly.Also check you adapter that it has a continues power supply by changing using the other same type adapter.
** you should clear this problem out fast cos this will cos a permanent damage to your laptop.
takecare.
