Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
About motorola t5720
Hi there Neto!
my name is Luka and im from Croatia.
well i haw this problem with my pair of Motorola s but i dont have anyone in my vicinity to ask about the problem. so if u are willing to give any advice id would be very thankful .
the problem is next:
the radios work fine ONLY when they are on the same channel and the sub channel is set on 0 (zero). otherwise they dont have communication. i mean they have but only in one direction. i saw on other posts that u are talking about CTCSS in my case QT but when i turn it on there is no communication at all.
so im asking u is there any way to reset them or something like that bec.
i bought them over ebay and turnin them back would be only loosing money. and yes...when i bought them they were working fine,
thanx allot
please rply to pinggpongg2001@yahoo.com
peace
LUKA
  • 123 Answers
Hello, Thanks for requst me, As far as I understood, you have same settings in both radios, you mentined QT this is the 3° requirment to recive a signal, 1° channel, 2° subchannel (ctcss, pl, etc) and the 3° QT.
if you are using QT you must to send a Call from the other radio, I recomed to set the QT to Off in both radios and tray if you can communicate in both directions.
if does not receive, there is the possibility that one of your radios the Sub channel decoder is not working.
If you could test your radios with a Third radio to know wich radio is not working right.
Good luck
Posted on Apr 28, 2008
I have a pair of motorola t5720, but the problem only 1 is getting on, the other 1`s power is der but no display nd nothing like stuck. .wat shud i do?
Try swapping the known good battery out of your working unit and see if that solves the problem. If so, replace the battery pack. If this is not the problem, unfortunately your best option is to replace the one unit. Parts and schematics were never made available for this model.
Best regards.
Apr 28, 2014 | Motorola Talkabout T5720 (7 Channels)...
Talkabout t5022 cannot talk with t5720 how do I pair them?
Look for the user guides here http://shop.giantintl.com/Manuals.asp?offset=30
Sep 09, 2013 | Motorola Talkabout T5720 (7 Channels)...
Does motorola Talkabout T5720 2 way radio have a identification number to locate possible owner of the handset?
These are mass produced radios which although serial numbered inside under batterys - it is very unlikely that you will trace an owner. cheap and cheerful radios dont usually attract the effort to register
Apr 30, 2010 | Motorola Talkabout T5720 (7 Channels)...
I had a pair of t5720's but lost one of them on a trail somewhere in Arkansas. Where can I order a replacement?
You could try eBay, or Motorola's online store http://www.store.motorola.com/mot/en/US/adirect/motorola?cmd=catDisplayStyle&catKey=601700
or you should be able to get a similar unit at your local Walmart. The T5720 has not been produced for a while, but other TalkAbout radios will communicate with your existing radio.
Best regards.
Feb 18, 2010 | Motorola Talkabout T5720 (7 Channels)...
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 circuit schematic
We are a M dealer and the schematics for the TalkAbout line were never released to the dealer channel.
Jul 13, 2008 | Motorola Talkabout T5720 (7 Channels)...
Problem transmitting
Hello jayhawkrx,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a Privacy Code or Quiet Code. The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on one of your radios but not on the other. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code 4 on the Motorola TalkAbout series actually corresponds to code A on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Mar 09, 2008 | Motorola Talkabout T5720 (7 Channels)...
Comms problem between motorola t5522 and t5720
Are you sure both radios has the same Squelch Code and QT?
Jul 07, 2007 | Motorola Talkabout T5720 (7 Channels)...
Communication problem with my brend new T5720.
I have seen some problems with new out of box radios, one of them is out of frequency and recieve with noise and works with low range coverage. I can not clarify what you mean with feed back, check if you set in low volume if the radio works fine. That will tell you that the speaker or the Synth circuitry has a problem. Neto.
Dec 06, 2006 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
281 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
