Duet washer, i had water shut off to unit, and kids started it. Now water is on and it wont unlock, and runs,not turning the drum. tried unplugging, tried pushing, holding all buttons, any help?
    President:
  • Washing Mach... Master
  • 2,651 Answers
Slect drain/spin cycle and try running that one, before it starts anycycle this achine will unlocka nd relock the door mechanism. if uyou try this what does it do??? any response???
Posted on Apr 29, 2008
Whirlpool front load washer model WFW9050XW00 - Machine stopped still loaded and with door locked. I was able to unlock and remove clothes leaving water and heavy suds. Tried running drain-spin and...
Your pump is jammed with a blockage, remove the filter and check the pump behind it is revolving, usually a hair grip or button in there...remember the washer is full of water so you will have a lot of water coming out
Sep 05, 2017 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet front load washer. when I put a load in on normal cycle, at some point it was flashing an H and an F on the display. Tried to pause it and unlock the door, but nothing happened....
Whirlpool's 'FH' decodes as 'no water inlet'- I suspect 'Hot Fault'!
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Clothing jammed front of washer and pulled front apron/seal away which caused water to leak out front. Fixed the seal and turn the washer on. The water turns on to fill the basket but now the motor will...
have you tried unplugging unit for a couple of minutes to reset? if so it is possible the motor control got wet and this could be the culprit. there are also some wiring around the front of unit are we positive nothing got disconnected... let me know
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Water in drum when washer isn't running
Water fill valve ..Also.try outlet pipe not too low, water could be comming from sink back into machine...
Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet clothes washer will work for the first 7 minutes and then F20 (Water Inlet Problem) flashes. I've tried unplugging it overnight and that didn't help. It's getting water fine during the...
F20
NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED. The pressure switch is not tripped after 6 minutes. Possible Causes/Procedure If there is no water in the unit: – Make sure that both valves at the water source(s) are turned on all the way. – Check for plugged or kinked inlet hoses or plugged screens in the inlet valves. – Verify inlet valve operation. If there is water in the unit: – Verify drain pump operation. – Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch. 1. Verify there is not a siphon problem. 2. Press PAUSE/CANCEL twice to clear the display. The machine will drain for 3 minutes before unlocking the door. 3. Unplug washer or disconnect power. 4. Verify wire harness connections to inlet valves, pressure switch, drain pump and Central Control Unit (CCU). 5. Check all hoses for possible leaks. 6. Plug in washer or reconnect power 7. Verify pressure switch operation. 8. Verify CCU operation by running a Diagnostic Test or any cycle.
Jun 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking water into the drum when not used
water leakin in tho the drum is sign of a faulty water inlet valve, not shutting off water supply to machine, it continues to trickle in , in beween washes. you can turn off the water supply between washes see if this helps, and if it does then youll know its the water valve
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loader GHW9150 PW
Yes, I fixed it after 10 hours of attempting. I called Whirlpool who in turn told me to call a Tech out to the house. I talked with a Whirlpool Rep who was at our local Lowe's, she in turn called their Whirlpool Guru who told her, there is NO override or manual way to fix the lock up unit/problem other than calling a Technician.
Well, I beg to differ. I took the panel off a 2nd time, looked for a pull, which there wasn't one, so I keeped feeling around the lock from the inside of the washer. I looked for anything that would move, press together, pull down and walla, bingo, I found a piece of metal that I pulled on and it released the door!!!!!!! Yahoo, then while the door was opened, I plugged the unit into the AC, it recognized that the door was unclocked, then I turned it to spin and rinse after it started flashing the F 11 code. I knew from this site, that it meant my soap had leaked into the unit. After running the rinse cycle, I am so proud to report that the machine is back up and running!!!!!
I thought, how awful not to have an external manual release, what if a kid got locked in the unit. Yes, a kid. My brother and I use to tumble in the dryer...lol Kids do, do dumb things. So even if Whirlpool tells you it can't be done,without a technician YOU can do it!!!! I'm a 60 year old woman and proud of it....Thanx FixYa
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer stuck in Drain mode, flashes same time, can't unlock control or pause/stop
ck to see if any water in drum if so possible pump clogged ..remove bottom panel pump will have clean out port with large knob turn counterclockwise ..expect flood if water inside but can't be helped if washer is on pedistal open drawer and try setting bucket underneath and have towels handy..after cleaning reinstall port cover and try again..if no water in tub try unplugging hold power button down 20-30 secs and reconnect still have problem door can be unlocked by removing bottom panel and pulling small tab just below lock assembly from underneath
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
