60inch Philips Rear Projection
What is the web site for the convergence problem? I have this problem and I would love to fix my tv.
  • 8,617 Answers
Heres the link . leave them an email indicating the model number of your set and they will get back to you usually within a half hr with the correct number STK ICs you need, or answer any other question that you may have.
http://servicemanuals.vstore.ca/
Posted on Apr 29, 2008
I am trying to set the convergence on my 60inch projection tv however the red will not converge with the green on numbers 1,3,4,6,7,9..How do I fix that?
hello, the reason for this is down to the convergance ic at the back of the tv, 2 big black chips sit on a metal frame called a heatsink they are usually located behind the tuner board, also you will have to test the resistors and the 2 capacitors at either end hope you can get it repaired
regards
shaun
Nov 21, 2010 | Toshiba 55H70 55" Rear Projection...
My Philips 60inch widescreen rear Projection the picture color is blue and red how can i fix it
Tv problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Philips 60PP9202 60" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
The picture is wavy on my 60inch philips hd tv
Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • TV may shut down after having the above symptoms.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 30, 2009 | Philips 60PP9352 60" Rear Projection...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
Can not line up red convergence
The convergence chips are toast. This is a common problem. Goto the site www.TvRepairKits.com to get a repair kit with instructions.
Dec 22, 2008 | Philips 60PP9202 60" Rear Projection...
I need help finding a protective screen for a philips 9P6031C 60inch rear projection tv
I may salvage the parts from my set if I cant fix my problem for a reasonable price. I have a projection screen for the 9P6031C, that I may sale if I cant fix the convergence on my set. The screen is in mint condition.
Aug 06, 2008 | Philips 9P6031C 60" Rear Projection...
Blue convergance off
Good Day, workdoggy200;
More than likely the TV has poor solder connections on the Convergence IC's, and by moving the TV these connections became worse. The original "poor connections" develope from the heating up and down of the Circuit. The IC's may have damaged and would have to replaced. Call an Authorized Service Center to come out and give a written estimate b4 repairing. Good Luck, big IRISH.
Aug 06, 2008 | Philips 60PP9352 60" Rear Projection...
Problem with phillips 60 projection tv
Possible cause could be a defective HVG (5904). Replace part with part number listed in this service manual.
Possible cause could be a defective Convergence
Amps (7044 and 7045) on Small Signal Module.
Replace part with part number listed in service manual.
Jul 29, 2008 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
